| Pioneer DV-717 stays in standy mode, did it die?
I have a problem with my old Pioneer DV-717. After noticing some image artefacts on my LCD TV I changed my SCART cable to see if it caused the problem. Well it didn't. But after changing the SCART cable from AV1 to 2 I did notice the artifacts were gone. Since the first SCART cable was a high quality one, I decided to use that one again. I disconnected the first one and first connected the other one. First to the DVD player and then to the TV. I noticed a bit of "leakedge" when I touched the chassis of the DVD with my elbow connecting it to the TV, but didn't give it any notice. I saw the DVD player was in standby mode and tried to start it up, but... nothing. The standby indicator just lights up when I push the On/OFF button. When I push Standby/start/eject on the remote or play and eject on the machine, the light will go off for a couple of seconds and then back on. It will not come out of standby mode. I have no mod chip in the small slot on the right side, the fuse is not defect and the machine doesn't smell burned or something in the inside. What could have happened? Can somebody help me, please? I sort of like the quality of this old machine and it was going to spend its last years in my bedroom setup. Or has it died on me already? Many thanks for your advice!
