Originally Posted by sTaD Anyone got this and if so any good?
I have a LE40 Samsung...any good |
Have you a 1080p Samsung?
If so you'd be better off waiting for the new Samsung 1080p7 player which is due out shortly, and will only cost a few £ more.
You also need to take into account that your TV will probably do as good a job of scaling (if not better) as the DVD Player.
You get what you pay for really with these budget players, as the scaling processors can't be that good at the price.
If you want to get the best out of your standard DVD collection, then you should really be looking at the Toshiba XE1 HD DVD Player which has the Reon Processor and can upscale ordinary DVD's to 1080p. You can get it for around £470 if you shop around.
Your current DVD Player (if you have one) will probably do just as good a job as the Samsung you are looking at buying, even though it doesn't have a built in scaler.
