Originally posted by chg Is there anything I can do to the player to maybe output in PAL or something? Or would I just need to get a new TV??
Thanks!! |
1)with no disc in machine, put player into standby mode
2) hold >>| (skip button) and press power
on front panel of dvd player it will say NTSC or PAL or AUTO
repateat step 1 & 2 unitl the player says PAL
3)Change the video out setting from VIDEO to RGB. If you can't find this menu read the manual
This should sort it... if not then you'll have to try compromise as your tv can't handle PAL60, RGB or NTSC
