Originally Posted by dvdguy23 Firstly do all HDMI DVD players upscale? I think they do, Im not sure. |
Most do but not all.
Originally Posted by dvdguy23 All HD ready screens show the maximum resolution possible from the source input (sky hd, Blu-ray, DVD player) etc....
HD ready 'panel' screen will always show at thei native resolution of the panel. It is upto you what you feed the. 1080i, 720, 576p, 576i etc
Originally Posted by dvdguy23 Now My dvd upscaler via HDMI allows my tv to show 720p with a way better image then normal dvd playback via scart and better than componant. |
You are changing several things all at the same time and concluding upscaling and HDMI is the difference. I would say that it is more likely to be down to the poor quality of the analogue interface and the display deinterlacing properties.
Originally Posted by dvdguy23 My conclusion is that the tv upscaler (do all hd TV's have their own scaler?) and the dvd upscaler go hand in hand. U need a device capable of sending upscaled video to your screen for the tv to output it!
Am I right?? Or can TV upscalers do this by itself?? If that were true then why would u need sky hd for example?? |
a HD Ready display will upscale (and deinterlace where necessary) any compatible signal to fit the native resolution of the display, that could be a Blu ray HD signal or an low quality SD signal from a VHS deck.
Yo only need one upscaler, one good one. Today manufacturers prefer to sell you one in a DVD player, one in a receiver and one in a display and most of us fall for it....and manufacturers just make more money that way. Any one of these three solutions work fine, the trick is just to use you 'best' one you have access to, many are very similar however particularly if you just need to scale.
