| Re: Upscaling DVD player...advice pls
Theres good value in the market right now for upscaling players. If your on a budget then the 696 seems good value at around 100 pounds, I bought the denon 1730 and picture quality via component is very good sound is excellent as well. Your other choices are the sony ns76 which is similar to the above.
If your budget is stretch the other is the pioneer 490 at around 55 pounds that upscales but has issues with PAL dvd's due to the older chipset which is the mediatek. The pioneer 696 has a newer mediatek chipset and does have these issues.
Anyway I would go for the denon. Plays everything i have thrown at it so far. Build quality is good too. Manual remote and menus are terrible though but it is minor issue once you get to use it.
