Progressive Or Interlaced ?
Old 30-01-2007, 3:13 PM   #1
13,972, Level: 28
Points: 13,972, Level: 28 Points: 13,972, Level: 28 Points: 13,972, Level: 28
Thanks: Gave 27, Got 45
I know this qustion has no doubt been asked a million times before, have tried a search but the results are far too many to trawl through.
Have recently set my DVD player to use progressive via Componant, previously it was interlaced via RGB Scart.
I know progressive is meant to be better, what should I be looking out for, and how is progressive better?
My kit is in my sig. thanks in advance.
Old 30-01-2007, 4:43 PM   #2
spooney's Avatar
9,145, Level: 22
Points: 9,145, Level: 22 Points: 9,145, Level: 22 Points: 9,145, Level: 22
Thanks: Gave 53, Got 220
Re: Progressive Or Interlaced ?
In my understanding only CRTs use interlaced signals all other displays and projectors need deinterlace the picture at least this is true for LCD.
The problem with interlaced signal is a certain flickering. This is why 100HZ CTRs were introduced (including a whole set of new problems like the visible track of a flying ball, etc.)
On a DVD is either movie material (24 full pictures per second) or video material (50 half pictures per second in PAL). Your display shows 25 pictures per second ( I know this is weired but this is how it works) and the de-interlacer has to make sure both source materials are displayed properly:
Either put the video pictures together to a full picture or convert the 24 to 25. Actually there should be flags to trigger this on the DVD but most of the time they are not set properly. This is the progressive output.
In general: A good display/projector will do a better job then a standard DVD player.
Old 30-01-2007, 5:09 PM   #3
13,972, Level: 28
So with my kit I am better with progressive via componant?
Old 30-01-2007, 5:28 PM   #4
Assured Advertiser
6,251, Level: 18
Points: 6,251, Level: 18 Points: 6,251, Level: 18 Points: 6,251, Level: 18
Thanks: Gave 6, Got 47
You have two choices:-
Send an interlaced signal from the DVD player and let the screen de-interlace it (flat panels are inherently progessive)
or
de-interlace the signal in the DVD player and send the progressive image to the screen.
I would say there is a good chance that the de-interlacer in your £2000ish screen will be better than the one in your £200ish DVD player.
The absolutely, above all else, most important question is...
Which looks better to you?
www.kenthomecinema.co.uk - Proud to be be supporting the AVForums as an Assured Advertiser.
ISF Certified
CEDIA Professional Designer
Old 30-01-2007, 7:00 PM   #5
13,972, Level: 28
Thats the thing, I cant really tell to be honest, but just wondering what is the advantage of me switching to progressive via componant over interlaced via rgb scart?
Old 30-01-2007, 7:18 PM   #6
SquintingBadger
Posts: n/a
This might help
http://www.100fps.com/
Old 30-01-2007, 7:22 PM   #7
Illustrious Member
40,968, Level: 49
Points: 40,968, Level: 49 Points: 40,968, Level: 49 Points: 40,968, Level: 49
Activity: 29.1%
Activity: 29.1% Activity: 29.1% Activity: 29.1%
Thanks: Gave 277, Got 1,647
MY BenQ W100 has PS. As it has two component inputs, I attached a player with interlaced component and another with PS in the player on the other component. I couldn't tell the difference.
While that is true nowadays. My Panny PTAE100 does not have it so, I had to do it in the player.
Old 30-01-2007, 8:55 PM   #8
13,972, Level: 28
Originally Posted by SquintingBadger View Post
This might help
Hmm this is all so confusing!
progressive via componant will give me a more detailed picture however interlaced via rgb scart will give me a smoother one?
is that correct?
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 2:30pm. Prices include delivery.
