Originally Posted by tman Well, after 2 years of service, looks like my multiregion Pioneer 575A is about to croak. Takes ages to read a disk, and will then sometimes stall while playing. I guess the motor is on the way out, as it makes some odd noises.
Therefore, I'm looking for a replacement, but I have some specific criteria due to my plans to move abroad this year.
I still have an SD plasma at the moment, so progressive analogue component is the best connection I can use. What's as good as or better than the 575 over component at the moment? I know everyone seems to have an HDMI fixation, and it would make sense for any player I get to also have HDMI for the future, but it's component only for now.
I need it to be multi-region with RCE (my 575 is chipped).
I don't want to spend a huge amount on this, something < £150 would be good.
Lastly, with my plans, I would like the player to work on 110/240v 50/60Hz without needing a stepup/stepdown transformer. This may be the tricky bit.
Any recommendations? |
I've just replaced my 575A with a 696AV. It has all the features of the 575 plus an HDMI port.
It wasn't multiregion but it is easily made multiregion if you have a PDA or something like a Philips Pronto remote using thne info
here, and plays RCE disks OK.
I paid £92 for mine from Pixmania whith their VIPix discount.
The voltage is a tricky one because the Region 2 version is 220V 50/60Hz, although Purely Gadgets have been/are selling multiregioned Region 3 models which should be 110/220V. The R3 models don't have a SCART but since you are interested in component output, it won't be a problem.
