Originally Posted by davepuma I'm afraid if it's a SD TV, an upscaling DVD player wouldn't work. However, if the TV supports progressive scan (check manual) get a decent progressive scan DVD player (even one with HDMI output) and connect via component. It will output in 576p. If the TV is SD, then HDMI is a no-go as it is for HD resolutions ie 720 upwards.
Your HD content won't work unless you can get the output from the PC (I presume it's a PC) to match the TV. Try using Powerstrip (free download from the net, try googling it) to get the graphics card to adjust the resolution to one that matches the TV. Check your manual for supported resolutions. You'll find more info on Powerstrip etc in the HD Hardware and Entertainment PC's forums. |
thanks for the info man..
Dont worry bout "Powerstrip"....
i know what it is...I'm a computer tech junkie....
What I'm not very good at is understanding this Upscaling stuff...
Here's what i know...
My plasma is SD and ..yeah..it has progressive scan...i guess ALL plasmas do...
You say that an Upscaling DVD player would not even work with my screen??
And what if I got an HDMI board for the screen??
thanks..
