Originally Posted by Matt_C Ahh, I see. Contrary to what you might belive, I do actually know what anamorphic is and how it works, I jsut had not attributed the two together...
It doesn't bother me that much to change DVD player no - I only just got this DVD player today, and previous to today, I coudln't play divx full stop, so as it now, it's a bonus. Certainly saves on converting it to DVD VTS/VOB files and burning to DVD-R! |
I find it makes life a lot quicker and simpler, and in theory it should look at least as good as going through the hassle and time of converting to Mpeg2.
Originally Posted by Matt_C Just curious then, how if a DVD is ripped to DivX and isn't anamorphic (as in a 1.85:1 ratio inside a 4:3 frame), makes me wonder what the original format was - anamorphic or not... |
Depends on how it was encoded. There are display aspect ratios stored in avi files that should tell the player how deal with this issue. The player could just be made clever enough to play back an avi correctly by looking at the resolution of the input file. Normally a DivX wouldn't contain any black borders, so it would not be in a DVD-standard resolution, and the player would be expected to deal with this correctly based on the resolution and headers of the .AVI.
You might try looking at
Mpeg4modifier to see if fiddling with the .AVI's header info will help you. The basic consensus seems to be that Sony has done the minumum to say they can support Divx, and isn't interested in doing it properly. Maybe they just don't deal with display ratios when they should do.
Originally Posted by Matt_C Either way it wsa just a question - and I DID add on there that I was most likely wrong as all this a tad new to me  |
The world of PC based codecs is ridiculously complicated, so don't feel too bad. There are a few of the more exotic players that go out of their way to support these things very well (like KISS or Snazio) and the newer Philips is pretty good. I think the new Pioneers are the best of the mainstream companies, as they seem to be able to play almost any DivX/Xvid above and beyond the call of duty.
It's a real pity that Sony only pay lip service to their DivX support, because otherwise their newer models like the NS76/92 seem to be very well received, but I guess it's just not very high on their priority list.
