Originally Posted by daveywavey007 I'm after a player to replace my ageing Toshiba SD-210E. I want it to play DIVX and Upscaling would be an advantage and DTS out, as I have a Sony HT-K250 Home Theatre kit.
Looks like it's a toss between Philips DVP 5960 and Panasonic DVDS52. Bugdet is £100 max. I'd appreciate your thoughts/suggestions/recommendatons. |
5960, this is the one you need a firm ware upgrade to make DTS and HDMI work porperly? I think there are some threads in the forum.
I own a S52 and can fully recommend it. Great picture and great sound via coax. You can make it easly region free via a remote like Pronto and there is a firmware available to disable UOP (the annouying "sit-through-anti-piracy-and-mandatory-adverts-and-trailer" sessions or you have to interupt the movie go back to menue and change the audio track instead of pressing the audio button on the remote))
