svcd and toshiba sd210E
Old 09-07-2002, 9:39 AM   #1
4,684, Level: 16
Points: 4,684, Level: 16 Points: 4,684, Level: 16 Points: 4,684, Level: 16
Activity: 1.6%
Activity: 1.6% Activity: 1.6% Activity: 1.6%
Thanks: Gave 9, Got 2
Thumbs down svcd and toshiba sd210E
hi
does anyone have problems playing svcd (cdr/rw) on the toshiba sd210 E. the video on mine is fine but there are lip sync problems with the audio lagging by up to half a second. is there a firmware upgrade to solve this and if so where do i get it. i've tried toshiba and toshiba uk sites and they were useless.
tia
Old 10-07-2002, 12:43 PM   #2
4,684, Level: 16
Activity: 1.6%
anybody ?
Old 10-07-2002, 1:49 PM   #3
Johnny_P
Posts: n/a
I have the newer SD220 and am experiencing the same problems. I have yet to find a solution to the problem !!
If I come across anything I'll let you know.
**UPDATE**
Finally got to speak to a tech at toshiba, who isn't surprised that SVCDs have an audio lag as neither their old or new players support the format
Old 10-07-2002, 2:19 PM   #4
4,684, Level: 16
Activity: 1.6%
thanks johnny, i didnt think it was going to be easy to sort out.
Old 11-07-2002, 2:13 PM   #5
laurel
Posts: n/a
I had the same problem a while back.
There were some reports over at www.vcdhelp.com that a firmware update solved the problem, however this doesn't work.
There are a couple of things you can do. The first is to introduce a time delay into the audio to sync to two up.
The second is my own solution and it works for me. That's to remove any menu's or titles/logo's from the beginning of the SVCD.
This is easy if your generating your own SVCD's like me as you just change the production method. If your buying SVCD's all you could do is edit them and output back to a new cd. Of course your gonna need a suitable PC and software to do it.
All my home made SVCD's now work perfectly.
Laurel
Old 12-07-2002, 8:59 AM   #6
Thanks: Gave 6, Got 21
For the peeps with vcd probs, from the vcd helper site:
I though the sd210e was brilliant in picture quality until I upgraded to the Toshiba sd220e which is even better and gets around the problem of svcd lip-sync by pressing angle button twice, ie too switch audio1,audio2,and back to audio1. Ps If you want too know the version of firmware your player is using, then switch on player no disk and on the remote press zoom 606 zoom its that easy.
hope it helps chaps.
Old 12-07-2002, 9:34 AM   #7
4,684, Level: 16
Activity: 1.6%
Talking
thanks everyone for the advice
Old 13-07-2002, 3:33 AM   #8
Johnny_P
Posts: n/a
Excellent post wassap, double angle button press works perfectly :0)
Many thanks for the info.
Old 13-07-2002, 8:27 AM   #9
I always aim to please!!
Now can someone tell me how to check whether my player is multiregion
Old 14-07-2002, 9:09 AM   #10
andypandy's Avatar
9,125, Level: 22
Points: 9,125, Level: 22 Points: 9,125, Level: 22 Points: 9,125, Level: 22
Thanks: Gave 13, Got 11
loan, rent, borrow a region1 disk & try ?!!
Or was that a joke ?
Old 14-07-2002, 3:25 PM   #11
nah i just wondered if the firmware would tell ya?
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 1:30pm. Prices include delivery.
