Originally Posted by watcher666 I know this is a really stupid question but i thought id ask anyway!
Will a Blu-Ray or HD-DVD work on a standard tv?
I know i wont see any picture improvement but my current DVD player seems to be on it's way out and so i thought i might as well go for one of the new formats. At least that way the movies i buy will be "future proof" so to speak. |
It's not a stupid question and many others are probably in the same boat. To answer your question high def material will work on your standard def TV - even if your TV doesn't support high def input then you can downscale on the player.
And you should see an improvement in picture quality. Not so much in detail but the lack of artifacts. I hooked up my HD DVD XA1 upto my old PW7 standard def plasma and the pciture looked very good: like an extremely well mastered DVD.
