Best Upscale Dvd Player
Old 28-08-2006, 6:13 PM   #1
2,596, Level: 11
Points: 2,596, Level: 11 Points: 2,596, Level: 11 Points: 2,596, Level: 11
Thanks: Gave 1, Got 1
Looking to buy a standalone dvd player which has a good UPSCALE HDMI output.
Can anybody advise which are some of the better systems to look at
Thanks in advance
Old 28-08-2006, 6:46 PM   #2
Illustrious Member
48,563, Level: 53
Points: 48,563, Level: 53 Points: 48,563, Level: 53 Points: 48,563, Level: 53
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 884, Got 1,284
Re: Best Upscale Dvd Player
Onkyo 1000 or the big Denon
Old 28-08-2006, 6:54 PM   #3
Lenny The Bruce
Posts: n/a
Would it not be better waiting until the HD DVD Players come out rather than buying an upscaling one?
Old 28-08-2006, 7:08 PM   #4
2,596, Level: 11
Judgin by the cost thats gonna be a while I would imagine ?
Old 28-08-2006, 7:37 PM   #5
Illustrious Member
48,563, Level: 53
Activity: 0.8%
The guy asked for a DVD player not a HD DVD player. The above DVD players will outperform a HD DVD player when playing a DVD.
Old 28-08-2006, 7:58 PM   #6
2,596, Level: 11
Thanks NIC> Correct i just want recommendations for STANDARD dvd playes with HDMI Output.. There are quite a few out between £60 and £200 for was after some advice
Old 29-08-2006, 2:44 PM   #7
5,775, Level: 18
Points: 5,775, Level: 18 Points: 5,775, Level: 18 Points: 5,775, Level: 18
Thanks: Gave 3, Got 9
Thanks in advance
I'm making serious plans to import the new Panasonic DVD-S99EG-S from Germany within the next 6 months. According to Panasonic.de website, it will be released next month.
Old 30-08-2006, 8:27 AM   #8
ykhan16's Avatar
5,709, Level: 17
Points: 5,709, Level: 17 Points: 5,709, Level: 17 Points: 5,709, Level: 17
Thanks: Gave 25, Got 13
The HD-A1 does a great job of upscaling and would outperform most SD dvd players apart from the top-end stuff- so its worth keeping in mind.
Old 30-08-2006, 8:40 AM   #9
12,048, Level: 26
Points: 12,048, Level: 26 Points: 12,048, Level: 26 Points: 12,048, Level: 26
Thanks: Gave 42, Got 92
Only if you only have Region 1 discs though currently.
Personally for a budget of £200 I would not worry about upscaling as its probably not going to be any better than the job your scaling chips in your plasma/lcd. (Hence why Nic mentioned the onkyo/Denon.. but they are alot more than £200)
Matt
Old 30-08-2006, 3:22 PM   #10
2,582, Level: 11
Points: 2,582, Level: 11 Points: 2,582, Level: 11 Points: 2,582, Level: 11
I have just replaced my Cambridge Audio Azur 540D with the new Cambridge Audio dvd89, The upgrade in pq coupled with my pio 436 is awesome
via hdmi ( imo ). Richer Sounds sell the CA DVD89 for £199.99
regards
Dan
Old 30-08-2006, 3:41 PM   #11
Conspicuous Member
Crustyloafer's Avatar
32,626, Level: 44
Points: 32,626, Level: 44 Points: 32,626, Level: 44 Points: 32,626, Level: 44
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 200, Got 1,226
Matt
I'll echo those comments, upscaling built into players isn't worth bothering with until you are looking at the £1000+ price bracket. For £200 I would concentrate on getting a player that gives a good non-scaled picture. A second hand Arcam DV78 might be possible near that price.
Old 30-08-2006, 3:48 PM   #12
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
The thing is no one has asked what will you connect it too? and why do you want to use HDMI (HIGH DEFINITION MULTIMEDIA INTERFACE) for DVD a standard defintiion format??????????
HDMI IS NOT BETTER and upscaling? How does that benefit you?
I agree with crustyloafer (it had to happen) look for a good DVD player like an Arcam or high end Denon etc not one with lots of marketig man rubbish and poor electronics
Old 30-08-2006, 9:33 PM   #13
sonny's Avatar
5,496, Level: 17
Points: 5,496, Level: 17 Points: 5,496, Level: 17 Points: 5,496, Level: 17
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 0, Got 7
All this upscaling/hdmi that the industry is telling us we must have is por advice. My player (Sony NS92) upscales through hdmi, but the picture through component is better.
Do a comprehensive comparison yourself and you will see.
Old 30-08-2006, 10:56 PM   #14
loz loz is offline
Conspicuous Member
30,195, Level: 42
Points: 30,195, Level: 42 Points: 30,195, Level: 42 Points: 30,195, Level: 42
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 281, Got 815
Or buy one with no marketing man rubbish, good electronics, and DVI/HDMI output, for just £179
Oppo 971H
Old 31-08-2006, 2:42 PM   #15
5,775, Level: 18
Oppo 971H
Oppo 971H are DVI only but supply a cable to convert to HDMI.
I've considered the Oppo, but since my most basic requirement is full HDMI interface, I will pass on it until Oppo release a version of the 971H that do.
A very similar machine with HDMI is the soon-to-be-released Panasonic S99 from Germany, the successor to the S97 which I've posted about earlier in this thread.
Old 31-08-2006, 8:58 PM   #16
2,596, Level: 11
I am connecting this to a SAGEM AXIUM 50"
I was under the impression the HDMI upscale would give me a better picture than my current Component output (LITEON 5045 Recorder)
is this not the case ?
Old 01-09-2006, 9:27 AM   #17
sonny's Avatar
5,496, Level: 17
Activity: 0.7%
Unless you are considering high-end gear, you will get a better picture from component. I have an upscaling player (Sony DVPNS92) and I tested it extensively with many dvd's using its hdmi output, and component was always better. This view was echoed by many specialist AV shops I asked.
Old 01-09-2006, 9:54 AM   #18
loz loz is offline
Conspicuous Member
30,195, Level: 42
Activity: 6.1%
Not necessarily. That is a rather sweeping generalization.
Old 01-09-2006, 2:26 PM   #19
Assured Advertiser
63,997, Level: 61
HDMI wont necassarily be any better your liteon is not at the top end of PQ anyway so a better DVD player is a good idea, as t whether HDMI is better will depend on your choice of DVD player and the TV some TV's process HDMI better than component.........some the other way around have a look at what other Sagem 50" owners are using...
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
Samsung DVD-D530
3 prices from
 £35.90 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
8 prices from
 £89.95 Click to show/hide the offers
 Updated February 10th at 4:30pm. Prices include delivery.
