ok, after some investigation, i found an article here:
http://www.homecinemachoice.com/cgi-...?reviewid=4542 which says the following when talking about connections? i
...and a single set of component video
RCAs. Strangely, the latter won’t accept
standard 576i from a DVD player but will
accept 576p PAL progressive scan, so those
with decks that only feed interlaced signals
can’t use the connection. However, you can
pipe high-def 1080i from a D-VHS player.
For those who don’t own a PAL
progressive scan DVD deck there are RGB
Scart, S-video and composite video
alternatives.
am not sure if this is relevant for me as further on in the article it says:
Movie Plus is disabled when using
component video input, but this isn’t
a problem as, for example, PAL prog
scan pictures fed from Harman
Kardon’s DVD30 looked sublime.
I have a DVD 22 which is the next model down so they have been viewed on HK kit in these tests, what i am wondering though is could this be a problem with my region 1 disks as everything above mentions PAL
although Philips confirm that the TV is NTSC compatable, but quite frankly im lost
