Philips DVP5960/05
Old 05-08-2006, 9:49 AM   #1
Thanks: Gave 21, Got 1
Philips DVP5960/05
Hey guys, just curious if anybody has any experience with the above DVD player, Im looking for something to compliment my Toshiba 32WLT66 lcd which is being delivered on Monday but im on a bit of a budget and these seem reasonably priced for the features (HDMI, Upscaling, Divx certification etc.)
I also have an xbox 360 and Ive heard that these upscale DVDs when using the VGA cable, I already have the VGA cable as I currently use it on my PC monitor (hard to tell wether it upscales or not thoough as its on a 22" Iiyama CRT). I know that chances are a stand alone player is going to be better but can anybody tell me how they rate the 360's DVD playback and upscaling, and is upscaling possible through component on the 360.
Any advice greatly appreciated.
Sean
Old 07-08-2006, 2:58 PM   #2
Entertainment's Avatar
Thanks: Gave 32, Got 11
PHILIPS DVP5900 hdmi player
Old 07-08-2006, 10:02 PM   #3
Thanks mate looks to be a slightly different model as the 5960 supports Divx Ultra which isnt mentioned on the 5900 other than that i would imagine they are pretty similar though Ill have a read. Good to get some advice off a fellow Geordie .
Heres a link to the 5960 specs
http://tinyurl.co.uk/ubzs [url shortened-forum moderator,lynx]
Old 07-08-2006, 10:03 PM   #4
Hmm sorry not sure how to make the link appear shorter.
Old 15-08-2006, 8:25 PM   #5
does anyone have this dvd player and know if you can connect a usb external hard drive to play movies off?
Old 15-08-2006, 10:56 PM   #6
hoggy1964
Posts: n/a
Region free codes
Dose anyone know how to region free a Philips DVP5960 as mine is fixed on region 2 only. Any help on this matter would be most helpful.
Old 15-08-2006, 11:11 PM   #7
Thanks: Gave 35, Got 12
http://www.videohelp.com/dvdhacks
Old 15-08-2006, 11:29 PM   #8
Thanks: Gave 3, Got 9
Coincidently, I've had this player for the past 6 weeks connected to my Toshiba HDTV via HDMI.
Plays all my R1, R2 and R4 DVDs without fault and give near HD quality.
BTW, the link for the DVP-5960 in another post in this thread is for DVP-5900. DVP-5900 use a totally different architecture and MPEG decoder.
The region hack at:
http://www.videohelp.com/dvdhacks.ph...&Search=Search
...works flawlessly.
Old 03-09-2006, 1:23 PM   #9
Re: Philips DVP5960/05
I've just got this player and it's working great so far. The hack at videohelp.com worked perfectly, there's no problems with dvd playback, it plays .mpg as well as .avi on DVDs (my dvd player before could only handle .mpg when on CD), it plays MP3-DVDs, and I've connected an external hardrive and it plays video files from that as well.
In fact the only problem I've encountered is that when I'm playing a divx disc or files from the hardrive I can't get back to the menu - am I missing something completely simple or are other people having problems with this?
Old 03-09-2006, 1:30 PM   #10
hig hig is offline
Thanks: Gave 1, Got 2
I have this player and have an Evesham V32EMRO-ZE3 coming tomorrow.
As the Phillips can output HDMI with upscaling AND component with prog scan, I was wondering is there any preference as to which I should connect with or are the differences negligable??
Thanks.
Old 04-09-2006, 10:50 PM   #11
If anyone else was having the same problem I was to get back to the menu you have to press stop twice. Not particularly intuitive, or mentioned in the manual, but hey: at least it works.
Old 09-09-2006, 1:25 PM   #12
i have this dvd player.....thru hdmi no 5.1 channel sound, contacted philips they said a software upgrade was available on ther website...i downloaded and installed and it killed the hdmi connection....philips said its a 1 off and i got the dvd player replaced.....downloaded the upgrade again and instaled it and hey presto....nmo hdmi signal again......sendidng dvd player back again and i do not ever want it replaced....look else where if i was you
Old 09-09-2006, 5:28 PM   #13
This Philips machine is an excellent choice for a video-based system. For the price, it's PQ is second to none. However, the audio section is rather rudimentary. If you require the latest in audio refinements, get the Pioneer 696.
I like the Philips, but it's simply a temporary primary machine until my Panasonic DVD-S99 arrives sometime early next year. Then it becomes my secondary player for R1 and R4 titles.
Old 06-04-2007, 2:39 PM   #14
Thanks: Gave 859, Got 598
I thought this was the one I was looking for as a temporary measure until the PS3's upscaling firmware upgrade Sony keep teasing us with.
I was planning to connect it via HDMI to upscale DVDs and hoping to connect the audio via optical out to an AV receiver.
From the specs, however, it doesn't seem to have an optical out is this correct?
Old 06-04-2007, 4:45 PM   #15
Thanks: Gave 86, Got 52
You are correct, the 5960 only has co-axial out , not optical
Delh68
KeanosMagicHat (12-04-2007)
