do you have digital audio setup for bitstream ? (otherwise your dvd is downmixing 5.1 to stereo and outputting as PCM)
Another question is: are you using correct input selection on your Amp ?
For dvd make sure that you assing digital connection in yor amp setup for DVD playing. You can use DV7600 decoders as well to the job then you must use 6.1 input (unless your amp have the option to assing 6.1 to analog DVD input then you just switch analog>digital )on your amp and chose 5.1 audio output on your DVD player
