I'm currently using a Pioneer DVD-575 player, connected via component to a Hitachi 7200 plasma, which overall gives very nice results indeed.
Basically, is it worth upgrading the player to one with HDMI or DVI, and upscaling capability? Are we talking "picture looks a little better" or "bugger me, that's nearly as good as HD"?
I've seen a few around the £150 mark, including
this Samsung, which Richer Sounds claim can do HD? I take it from that, they mean can upscale, not that it can play HD-DVD, which they seem to imply? I also rather like the look of the Denon 1920, if I can find it at a decent price?
If it is worth doing, what players would people recommend, as a good upgrade from my 575, without going above £200 ideally.
I've also noticed a few people comment on HDMI shift problems? What is it, how do I avoid it, or is it nothing of note to worry about?
DivX playback is essential, as is DVD-R (etc), DVD-A preferable, though not critical, and couldn't care less about SACD as I have a dedicated player for that.
Alternatively, assuming the Samsung doesn't (as I strongly suspect) handle HD-DVD, am I better off hanging on for an HD-DVD player?
Are there any pitfalls to watch out for, should I opt for a player that can upscale, "buggy" players to avoid etc.. Am I likely to encounter any problems or signal degradation if I use an HDMI to DVI converter, as I would prefer to use HDMI for Sky HD (when it's been installed). None of my DVD audio playback is done through the TV; it all goes to the amp, so the lack of sound on DVI is not an issue.
Finally, it MUST be multi-region, or handset hackable. Argos have a Samsung 850, which might be a possibilty, particuarly as I get discount, although it doesn't appear to handle DVD-A.
The whole HD & upscaling side of A/V are completely new territory for me, so any advice is very gratefully received.
Cheers!!
Ollie
