UK Samsung HD-950: Trouble with R1 DVDs
Hello everyone,
I've spent the better part of an hour wandering through different forums and search engines looking for someone who has suffered the same issue I am, but to no solution, so hopefully someone here can help.
Last month I decided to buy a new DVD player as my current one (Sony DAVDS-1000 entertainment system) doesn't have an easy means of modding to multi-region. Based on Internet/forum reviews I opted for the Samsung HD DVD-950 because of it's reasonable price and HDMI connection + upscaling.
I bought it from Richer Sounds who even provided the necessary code to make it multiregion (same as off most websites) and it worked fine. The player is multi-region, very straightforward.
It's connected to my TV (Sony KDFE50A12 50" LCD Projection) through the HDMI connection, and R2 discs play absolutely beautifully, sound and picture are amazing, Star Wars Ep. III can definitely show off my setup well....
However, R1 discs have a very annoying habit (that I can't seem to do anything about) in that the movies seem to jitter, skip, not sure how to describe it. You can see the playback on R1 discs is not smooth and fluent, slow pans seem to have a jog effect. I'm hoping someone knows what I'm trying to describe.
I know it's not the discs, I've tried better part of 20 different movies and compared them to the playback on a crappy £40 Bush player I've multi-regioned plus my super high-spec Alienware system. Playback on these is fine, so it's definitely my new Samsung player.
Anyway, has anyone any experience with this problem? I'd very much appreciate it if anyone could lend some help my way.
Thanks everyone.
