lens cleaners ?
Old 30-04-2006, 5:42 PM   #1
10,890, Level: 25
Points: 10,890, Level: 25 Points: 10,890, Level: 25 Points: 10,890, Level: 25
Activity: 11.0%
Activity: 11.0% Activity: 11.0% Activity: 11.0%
Thanks: Gave 303, Got 113
lens cleaners ?
evening all...was wondering if these lens cleaning discs that you can get are worth using?
i noticed some on the shelf today when i was out and about and was thinking that i never used one on the cd and dvd players i've got....did'nt know if it was a case of 'if it's not broke,dont fix it' or if it was worth using one every so often and if so are some better than others......or are they a waste of time?
any pointers most appreciated.
cheers
Old 30-04-2006, 6:03 PM   #2
jackal
Posts: n/a
Try getting Allsops DVD cleaner and use it oce every 100 hours. Laser lens assemblies can get very grubby after a while. The Allsop also has some great sound and image calibration tools.
Old 01-05-2006, 9:46 AM   #3
10,890, Level: 25
Activity: 11.0%
cheers for that....any ideas where you can purchase it?
Old 02-05-2006, 12:56 PM   #4
5,414, Level: 17
Points: 5,414, Level: 17 Points: 5,414, Level: 17 Points: 5,414, Level: 17
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 5, Got 134
Got mine off Flea-Bay - try doing a search
Old 02-05-2006, 3:00 PM   #5
gallium
Posts: n/a
The best way to clean the lens is to open the cover, and get a cotton bud soaked with lens cleaner and rub it over the laser lens. Works an absolute treat!
The "fluffy" lens cleaners simply cannot get into the concave lens cavity to clean things properly. DIY method is cheapest and gives best results.
Old 16-06-2006, 5:46 PM   #6
cammo500
Posts: n/a
what kind of oil can u use inside equipment?
i try and clean my lenses that way, buy opening up the lid and cotton budding the lens, how do you keep all those plastic gears and things lubricated because sometimes my dvd players squeeks when it plays a disc? 3 in 1 oil is no good because it will eat the plastic, is silicone grease or graphite any good?
Old 18-06-2006, 6:53 PM   #7
Knightshade's Avatar
11,666, Level: 25
Points: 11,666, Level: 25 Points: 11,666, Level: 25 Points: 11,666, Level: 25
Thanks: Gave 13, Got 51
Possibly not the best advice when any movement to the lens can reduce the players ability to read discs. Alright to do on a £100 disposable DVD player but I wouldn't risk it on something better.
Stick to regular disc cleaning methods and just use them frequently.
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
11 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 8:30am. Prices include delivery.
