Sony Dvp-ns76h
Old 27-02-2007, 1:21 PM   #1051
totomal
Posts: n/a
Re: Sony Dvp-ns76h
C'est un excellent lecteur ce sony DVP NS76.
Old 27-02-2007, 2:08 PM   #1052
3,393, Level: 13
Points: 3,393, Level: 13 Points: 3,393, Level: 13 Points: 3,393, Level: 13
Re: Sony Dvp-ns76h
Originally Posted by Combatcolin View Post
Plug in power cord, plug in HDMI cable and watch unscaled films.
What i did.
Not really interested in faffing around with the settings, very happy with this player.
To be honest my experience is pretty much the same. On my old TV I just ran the quick setup, which disabled the digital out and so on.
When I got my new TV and receiver I plugged in the HDMI cable and digital out, reran the setup, to enable all the new features. Other than that I just had a check to make sure all the fancy things (like sound processing mode things) were turned off.
So far I'm very happy with it.
Old 27-02-2007, 2:16 PM   #1053
3,027, Level: 12
Points: 3,027, Level: 12 Points: 3,027, Level: 12 Points: 3,027, Level: 12
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 15, Got 56
Re: Sony Dvp-ns76h
I haven't needed to change any of the picture quality settings - the defaults suit my CRT and projector admirably. It is always possible that some displays may be better with different settings, but it's probably best not to change them unless there's an obvious improvement.
Old 02-03-2007, 4:28 PM   #1054
wedgehog's Avatar
3,615, Level: 14
Points: 3,615, Level: 14 Points: 3,615, Level: 14 Points: 3,615, Level: 14
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 1, Got 14
Re: Sony Dvp-ns76h
If anyone wants the full service manual for this player let me know. Bob
Old 02-03-2007, 4:37 PM   #1055
5,152, Level: 17
Points: 5,152, Level: 17 Points: 5,152, Level: 17 Points: 5,152, Level: 17
Thanks: Gave 26, Got 9
Re: Sony Dvp-ns76h
Yes please
Can you PM it???
Old 02-03-2007, 4:41 PM   #1056
wedgehog's Avatar
3,615, Level: 14
Activity: 4.7%
Re: Sony Dvp-ns76h
Originally Posted by lydiachris View Post
Yes please
Can you PM it???
no but you can download it from my rapidshare account I will pm you the address. Bob
Old 02-03-2007, 4:43 PM   #1057
Submariner_HTC's Avatar
3,637, Level: 14
Points: 3,637, Level: 14 Points: 3,637, Level: 14 Points: 3,637, Level: 14
Thanks: Gave 1, Got 5
Re: Sony Dvp-ns76h
Me too, please
Old 02-03-2007, 4:50 PM   #1058
3,250, Level: 13
Points: 3,250, Level: 13 Points: 3,250, Level: 13 Points: 3,250, Level: 13
Thanks: Gave 3, Got 18
Re: Sony Dvp-ns76h
Please could you PM me it too
Tony
Old 02-03-2007, 5:14 PM   #1059
wedgehog's Avatar
3,615, Level: 14
Activity: 4.7%
Re: Sony Dvp-ns76h
Let me know you got it ok. Bob
Old 02-03-2007, 5:20 PM   #1060
3,637, Level: 14
Re: Sony Dvp-ns76h
Downloaded without a problem. Thanks.
Old 02-03-2007, 5:27 PM   #1061
Cmar-Ireland's Avatar
3,036, Level: 12
Points: 3,036, Level: 12 Points: 3,036, Level: 12 Points: 3,036, Level: 12
Re: Sony Dvp-ns76h
Me too please!
Edit: Cheers Bob
Ok now that I have the service manual, is there anything interesting that I can use it for?
Thanks!
Old 02-03-2007, 7:11 PM   #1062
3,027, Level: 12
Activity: 0.8%
Re: Sony Dvp-ns76h
And if it's not too much trouble I'd be grateful if you could PM the rapidshare address.
Old 02-03-2007, 7:13 PM   #1063
wedgehog's Avatar
3,615, Level: 14
Activity: 4.7%
Re: Sony Dvp-ns76h
Originally Posted by Cmar-Ireland View Post
Me too please!
Edit: Cheers Bob
Thanks!
Yes, repairing it if and when it goes wrong. Providing you have had the training to know what you are doing.
Old 02-03-2007, 8:08 PM   #1064
wedgehog's Avatar
3,615, Level: 14
Activity: 4.7%
Re: Sony Dvp-ns76h
Probably be easier if I just let you all help yourselves.
Code:
http://rapidshare.com/files/19018752/DVPNS76H_.pdf
Hope it's of some use to you all, but please if you don't know what you are doing DO NOT take the covers off. Bob
popester_uk (12-03-2007), puc (12-03-2007), xander73 (14-03-2007)
Old 03-03-2007, 11:29 AM   #1065
Anjou's Avatar
12,666, Level: 27
Points: 12,666, Level: 27 Points: 12,666, Level: 27 Points: 12,666, Level: 27
Thanks: Gave 79, Got 83
Re: Sony Dvp-ns76h
Can you PM the link to me as well, Bob.
Thanks.
Old 03-03-2007, 11:55 AM   #1066
wedgehog's Avatar
3,615, Level: 14
Activity: 4.7%
Re: Sony Dvp-ns76h
Thanks.
Just look at the post above yours
Old 04-03-2007, 1:11 PM   #1067
Ninto
Posts: n/a
Re: Sony Dvp-ns76h
I was thinking about buying this DVD player, but can anyone confirm whether it gives a noticibly better picture quality than a PS2 over component, and therefore is worth the money?
Also, does it upscale over component?
Old 04-03-2007, 4:08 PM   #1068
Mr-Bananas's Avatar
7,351, Level: 20
Points: 7,351, Level: 20 Points: 7,351, Level: 20 Points: 7,351, Level: 20
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 12, Got 134
Re: Sony Dvp-ns76h
I think you will find that a toaster will give a better picture than a PS2 !!!!
To answer your question, yes the NS76 will be a great deal better than a PS2.
Old 04-03-2007, 4:20 PM   #1069
Mr-Bananas's Avatar
7,351, Level: 20
Activity: 1.5%
Re: Sony Dvp-ns76h
Is there anyway to adjust the picture ratio in the service menu ?
I find that when the player is set to 720p or 1080i the picture is fractionally squashed horizontally (the THX circle is slightly oval)
Has anyone else experienced this, is there a firmware update to fix this ??
Old 06-03-2007, 7:56 PM   #1070
Ninto
Posts: n/a
Re: Sony Dvp-ns76h
Has anyone got any recommendations on where to buy this DVD player?
Obviously I'm looking for somewhere that is reliable and cheap.
Old 06-03-2007, 8:02 PM   #1071
3,697, Level: 14
Points: 3,697, Level: 14 Points: 3,697, Level: 14 Points: 3,697, Level: 14
Thanks: Gave 0, Got 3
Re: Sony Dvp-ns76h
Amazon?
Old 06-03-2007, 8:36 PM   #1072
4,811, Level: 16
Points: 4,811, Level: 16 Points: 4,811, Level: 16 Points: 4,811, Level: 16
Thanks: Gave 5, Got 1
Re: Sony Dvp-ns76h
I just got the multiregion version from KK Electronics
http://www.kkelectronics.co.uk/ViewP...e=PON06E000039
Nice player, surprised at just now small it is compared to the one it is replacing (which I thought was thin!)
Old 06-03-2007, 8:47 PM   #1073
3,290, Level: 13
Points: 3,290, Level: 13 Points: 3,290, Level: 13 Points: 3,290, Level: 13
Thanks: Gave 17, Got 24
Re: Sony Dvp-ns76h
Similar price here: http://www.superfi.co.uk/index.cfm/p...roduct_ID/2729
Old 06-03-2007, 11:54 PM   #1074
2,536, Level: 11
Points: 2,536, Level: 11 Points: 2,536, Level: 11 Points: 2,536, Level: 11
Thanks: Gave 1, Got 0
Re: Sony Dvp-ns76h
Hello all,
My first post so go easy on me!
I have seen this question asked a number of times but have not seen an answer, as I also have an interest am going to ask it again.
I have a 42" hitachi 9700 plasma, xbox 360 and the 360 hd dvd player which I connect via component (I don't think I can get 1080i if I use the VGA cable)
I have this week been researching upscale DVD players but the question bugging me is will I see an improvement over either the 360 itself or the hd dvd drive?
I don't mind the £100 if I will see a benefit but would hate to be underwhelmed.
Old 07-03-2007, 1:48 PM   #1075
wedgehog's Avatar
3,615, Level: 14
Activity: 4.7%
Re: Sony Dvp-ns76h
Originally Posted by nl7474 View Post
Hello all,
I have no idea what the picture is like from a 360 as I have never seen one. I thought they were for playing games on. All I can tell you is that on your 42 inch screen 720 spread across it will be better then 625 and 1080 will be better than both of those. The more information there is on the screen, the better the quality of the picture. Now then, as to whether you will actually see a difference that you think is worth spending the money on is mainly going to be down to what your expectations are and how good your vision is, go find one on display in Curry's or comet or the likes, they are doing HD displays now and ask the guy to show you 720 and 1080 and see what you think. For me personally I only have a 32 and as expected I don't see any difference between 720 and 1080. Bob
Old 07-03-2007, 1:53 PM   #1076
hottstuff's Avatar
7,467, Level: 20
Points: 7,467, Level: 20 Points: 7,467, Level: 20 Points: 7,467, Level: 20
Thanks: Gave 147, Got 159
Re: Sony Dvp-ns76h
Upscaling will always be debatable.
But IMO the ns76h is a better dvd player than the 360 , without a doubt.
Throw in nearly every divx/avi/xvid file playback/upscaling and you have one tasty player.
Old 07-03-2007, 3:24 PM   #1077
3,637, Level: 14
Re: Sony Dvp-ns76h
If you have the HD-DVD drive for the Xbox360, you could buy £100 of HD-DVD movies and the high definition discs will look the best. If you only want to play upscaled DVDs, then the Sony is a good option. Picture improvement can be a personal opinion, and you might not see a drastic improvement and certainly not as good as a high definition picture.
Old 07-03-2007, 9:21 PM   #1078
2,178, Level: 10
Points: 2,178, Level: 10 Points: 2,178, Level: 10 Points: 2,178, Level: 10
Re: Sony Dvp-ns76h
First of all, I would like to say a big HI to everyone on these boards. You all do a fantastic job of spreading knowledge and helping people out with regards to all thngs A/V.
I have a question that I hope somebody can answer...
I have recently purchased the ns76h (multi-region) but I can't seem to get the player to upscale my DVDs. I have it connected via HDMI to my LG 32LX2R LCD TV, but no matter what setting I put the DVD player to output at, my TV says that it is displaying at 576p.
I have tried connecting my PC to the HDMI port on my TV and this runs fine, outputting at 1360 x 768. I have even tried connecting the Sony to my DVI input (using an HDMI to DVI cable) but the TV still says it is displaying at 576p.
Does anyone know how I can get to display at 720p or 1080i?
Many thanks for any help in advance.
Cheers,
Munkee
Old 07-03-2007, 9:51 PM   #1079
wedgehog's Avatar
3,615, Level: 14
Activity: 4.7%
Re: Sony Dvp-ns76h
Cheers,
Munkee
Have you selected the HDMI to output at 720 or 1080 in the DVD's set up menu ?
Old 08-03-2007, 9:15 AM   #1080
2,178, Level: 10
Re: Sony Dvp-ns76h
Yep, I have tried all of the settings in the DVD menu (including the 'auto') setting.
The strange thing is that, when playing Region 1 DVDs in the player, the TV informs me that it is successfully displaying in either 720p or 1080i (depending on which setting the Sony is set to), but any Region 2 DVDs always display at 576p according to my TV.
It's almost as if the Sony quite happily upscales on R1 DVDs , but refuses to do the same thing on R2 DVDs.
Any ideas why?
1nce again, many thanks for any help :o)
Munkee
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 4:30pm. Prices include delivery.
