Sony Dvp-ns76h
Old 13-12-2006, 11:03 PM   #781
2,734, Level: 12
Points: 2,734, Level: 12 Points: 2,734, Level: 12 Points: 2,734, Level: 12
Thanks: Gave 5, Got 2
Re: Sony Dvp-ns76h
Saw one in my local Westgate (Co-op) for £100.
Old 14-12-2006, 10:08 AM   #782
3,736, Level: 14
Points: 3,736, Level: 14 Points: 3,736, Level: 14 Points: 3,736, Level: 14
Thanks: Gave 1, Got 1
Re: Sony Dvp-ns76h
Gultronics sells it for £83 (possibly the cheapest price)
Old 14-12-2006, 10:28 AM   #783
Illustrious Member
40,968, Level: 49
Points: 40,968, Level: 49 Points: 40,968, Level: 49 Points: 40,968, Level: 49
Activity: 29.1%
Activity: 29.1% Activity: 29.1% Activity: 29.1%
Thanks: Gave 277, Got 1,647
Re: Sony Dvp-ns76h
A few questions
How does the pic compare to the NS92?
Will the pic stay the same quality if I used HDMI to DVI?
Would it be much of an improvement over a Sony NS585 using component?
Old 14-12-2006, 1:42 PM   #784
2,854, Level: 12
Points: 2,854, Level: 12 Points: 2,854, Level: 12 Points: 2,854, Level: 12
Thanks: Gave 19, Got 7
Re: Sony Dvp-ns76h
sorry if a repost but what does the hdmi output? 576p/720p/1080i?
Old 14-12-2006, 2:06 PM   #785
2,734, Level: 12
Re: Sony Dvp-ns76h
All of the above, defaults to 1080i.
Looks very nice indeed, big improvment over RGB Scart.
Only slight downside is that you can't just cycle through the upscale settings, you need to stop the disc and then enter the menu.
Old 14-12-2006, 2:14 PM   #786
Submariner_HTC's Avatar
3,637, Level: 14
Points: 3,637, Level: 14 Points: 3,637, Level: 14 Points: 3,637, Level: 14
Thanks: Gave 1, Got 5
Re: Sony Dvp-ns76h
I don't know about the other questions, but I am using HDMI (Sony DVD) to DVI (NEC plasma) and the quality is great, much better than the component connection. AFAIK video quality does not change when using DVI, but you do lose two-way communication, for example, HDMI to HDMI means the display can tell the video source what is the best resolution for the display and set the video source to output that resolution. Not a big loss.
I used to own a Sony 730p DVD player and the Sony 76h is much, much better.
Old 14-12-2006, 2:21 PM   #787
Illustrious Member
40,968, Level: 49
Activity: 29.1%
Re: Sony Dvp-ns76h
Thanks.
Old 14-12-2006, 9:03 PM   #788
2,734, Level: 12
Re: Sony Dvp-ns76h
HDMI is a direct desendant of DVI, the video is the same it simply adds audio signals as well.
Old 14-12-2006, 9:06 PM   #789
4,551, Level: 16
Points: 4,551, Level: 16 Points: 4,551, Level: 16 Points: 4,551, Level: 16
Thanks: Gave 11, Got 5
Re: Sony Dvp-ns76h
Cant get any sound using coaxial, works fine with optical-any ideas??
Old 14-12-2006, 9:07 PM   #790
2,734, Level: 12
Re: Sony Dvp-ns76h
Can't remeber if you have to switch co-ax on or not.
Have a fiddle.
Old 14-12-2006, 9:34 PM   #791
4,445, Level: 15
Points: 4,445, Level: 15 Points: 4,445, Level: 15 Points: 4,445, Level: 15
Thanks: Gave 2, Got 4
Re: Sony Dvp-ns76h
You know chaps, I think I'm going to have to buy one of these!
Old 15-12-2006, 8:49 AM   #792
4,551, Level: 16
Re: Sony Dvp-ns76h
cant find anything in instructions to tell u to do this or how to??
Anyone help??
Old 15-12-2006, 9:14 AM   #793
WGLOVER's Avatar
7,175, Level: 20
Points: 7,175, Level: 20 Points: 7,175, Level: 20 Points: 7,175, Level: 20
Thanks: Gave 79, Got 128
Re: Sony Dvp-ns76h
Anyone help??
Do you not have to select the input on the amplifier?
Old 15-12-2006, 9:22 AM   #794
4,551, Level: 16
Re: Sony Dvp-ns76h
done that-im sure its the dvd player
Old 15-12-2006, 11:27 AM   #795
WGLOVER's Avatar
7,175, Level: 20
Re: Sony Dvp-ns76h
I've not tried coax., that's taken up by the TVDrive STB.
I'll have a look tonight.
Old 15-12-2006, 11:47 AM   #796
redmax's Avatar
6,497, Level: 19
Points: 6,497, Level: 19 Points: 6,497, Level: 19 Points: 6,497, Level: 19
Thanks: Gave 67, Got 37
Re: Sony Dvp-ns76h
You have to enable "digital out" in the system set up menu.
I got one of these from Superfi and although I have next to it a HTPC that cost me over £1000 I can say that the picture over HDMI is fantastic.
I have just watched Attack Of the Clones and the detail of the colours and sharpness blew me away.
Its like watching new movies all over again.
Buy one
Old 15-12-2006, 11:53 AM   #797
2,381, Level: 11
Points: 2,381, Level: 11 Points: 2,381, Level: 11 Points: 2,381, Level: 11
Thanks: Gave 25, Got 5
Re: Sony Dvp-ns76h
This is a great player, tried it out proper last night watching Last Samuri on a Sony kdl-40w2000 through HDMI.
Great picture and sound.
Highly recomended
Old 16-12-2006, 5:29 AM   #798
3,637, Level: 14
Re: Sony Dvp-ns76h
Have you tried changing cables? Any old RCA cable will do for testing purposes. Once digital out is set to on, within the Sony menu, the coax output should work, unless something is broken.
The other week my brother could not work out why his brand new yammy subwoofer was cutting out. When I checked, he had used an old RCA cable that was broken. If only he had used the cable that had come with the sub
Old 17-12-2006, 7:51 AM   #799
5,787, Level: 18
Points: 5,787, Level: 18 Points: 5,787, Level: 18 Points: 5,787, Level: 18
Thanks: Gave 62, Got 10
Re: Sony Dvp-ns76h
Originally Posted by Agent Cooper View Post
Just recieved the NS76 today as a replacement for my super Sony DVP 7700, which was like £7-800 here in Denmark when released. The component signal from the 7700 to my HS60 projector looks very good, but it was time to see what HDMI was all about. I'll update this thread when I get the time to play around with calibration in both projector and player this weekend. The Supra HDMI cable is 15 meters and set me back almost £100, but it should be very, very good.
Cheers.
@psikey - nice too hear that you like the performance of the NS76 very much. Any interesting observations during the time you set up your player you would like to share? Have you fiddled with the picturecontrols etc.?
Just wondering if you have any update on your comparisons? If its a good upgrade, I may well go out and get one today.
Old 17-12-2006, 11:48 AM   #800
6,093, Level: 18
Points: 6,093, Level: 18 Points: 6,093, Level: 18 Points: 6,093, Level: 18
Thanks: Gave 4, Got 29
Re: Sony Dvp-ns76h
just tested this player and keeps restarting/freezing when progressive is enabled...
With scart cable:
withotu progressive = Fine
With Progressive = Locks up
Same with hdmi cable.....happens on 75% of my films.
Top gun and minority report are fine, lotr, layer cake,gladiator andm atrix all do it.....
IS this faulty???
Old 17-12-2006, 12:58 PM   #801
3,637, Level: 14
Re: Sony Dvp-ns76h
IS this faulty???
Yes, it sounds faulty. Progressive works fine on mine.
Old 17-12-2006, 5:56 PM   #802
3,027, Level: 12
Points: 3,027, Level: 12 Points: 3,027, Level: 12 Points: 3,027, Level: 12
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 15, Got 56
Re: Sony Dvp-ns76h
And mine.
Old 17-12-2006, 8:11 PM   #803
4,072, Level: 15
Points: 4,072, Level: 15 Points: 4,072, Level: 15 Points: 4,072, Level: 15
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 14, Got 4
Exclamation Re: Sony Dvp-ns76h
what swung it for me was the disk resume - kids keep changing dvds. Is there a hack to play the feature straight away?
Ordered from Superfi on the 13.dec.06, after checking on the phone they had stock -still waiting. Got lazy over doing multiregion myself.
JohnLewis give a 2 year warranty. Is a year's worth of warranty worth £10? (I banged it on Nationwide CC to push to 2 but at JL would have pushed to 3)
Meanwhile I am still waiting for Barclaycard (or whoever they outsource this to) to mend a Toshiba sd-330E (got the 3rd year warranty om top of 2 from JL when Barclaycard were still doing it) - the courier failed to collect of Friday - WAITED FROM 12 TO 5.
Old 18-12-2006, 11:07 AM   #804
3,539, Level: 13
Points: 3,539, Level: 13 Points: 3,539, Level: 13 Points: 3,539, Level: 13
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 6, Got 4
Re: Sony Dvp-ns76h
Hi everyone
I'm thinking of getting one of these players for my father-in-law but am worried about making it multi-region - is the only way of doing this through a One For All remote?
Old 18-12-2006, 4:32 PM   #805
5,965, Level: 18
Points: 5,965, Level: 18 Points: 5,965, Level: 18 Points: 5,965, Level: 18
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 73, Got 26
Re: Sony Dvp-ns76h
I am thinking of recommending this player for a relative. She is waiting delivery of a sony 40X. Currently she has an all in one player, a sony DVA-S500, but it only has a S video connection, for the tv (i.e. no component or hdmi connection)
I thought she could use the S76H to play upscaled dvd via hdmi to the 40X, and use an optical connection from the S76H to the DVA-S500 for the sound.
Does anybody see any problem with this before I get to part with her cash?
Old 18-12-2006, 4:41 PM   #806
Illustrious Member
40,968, Level: 49
Activity: 29.1%
Re: Sony Dvp-ns76h
It should work fine but make sure the sony DAV-S500 has a optical in that accepts 5.1 first.
Old 18-12-2006, 5:18 PM   #807
5,965, Level: 18
Activity: 1.8%
Re: Sony Dvp-ns76h
Yep the manual states the DAV S500 has an optical in input. I think the output for the tv is composite and s video, so am I right in thinking the sony NS76H will give a better picture?
Old 18-12-2006, 5:40 PM   #808
3,027, Level: 12
Activity: 0.8%
Re: Sony Dvp-ns76h
Originally Posted by straygoat View Post
Hi everyone
You can also buy it already multi region, for example from http://www.superfi.co.uk/index.cfm/p...roduct_ID/2729
Old 18-12-2006, 6:14 PM   #809
Illustrious Member
40,968, Level: 49
Activity: 29.1%
Re: Sony Dvp-ns76h
If that TV has a HDMI socket then it will be loads better than composite and s video. The next best would be either component or RGB scart.
Old 18-12-2006, 6:37 PM   #810
2,734, Level: 12
Re: Sony Dvp-ns76h
HDMI is fantastic, a huge increase ove RGB Scart.
The only issue is that once you've got used to an upscaled HDMI image you can't go back, and as HDMI ports are limited expect HDMI switchbox's to become commonplace soon.
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 4:30pm. Prices include delivery.
