Originally Posted by unique as far as i know, the difference between the 850 and 950 is the 950 plays sacd and dvd audio as it has 6 phono stages at the back for analogue audio output. the 850 is silver and 950 is black |
The 950 has a built in dolby digital decoder ( processor) and therefore 6 channel analogue output (5.1) bypassing the need for an external AV amp if you have a self powered surround speaker set.
It also has the brightest display panel light in the (whole wide ) world
( can be turned off)
there are a few niggles with the 950, which you can read up on if you search here. i have the 950 and the niggles dont bother me anymore
Those niggles also apply to the 850 ( PAL/ NTSC auto switching, the HDMI not supported message)
Like you ,I only find them a minor irritation more than anything else
The PQ of 850/ 950 and the Phillips 5900 are pretty much the same, ( at 720p: great
if not earth shaking, but certainly not poor
PS: If this will sway you I understand the Phillips can now be had for £75-80, Try Richer sounds first
