Multi region?
Old 05-02-2006, 12:25 PM   #1
4,820, Level: 16
Points: 4,820, Level: 16 Points: 4,820, Level: 16 Points: 4,820, Level: 16
Multi region?
Hi ,
Probably a silly question, but can anyone tell me if my DVD player is multi-region before I buy a Region 1 DVD off ebay? (I have previously restricted myself to buying Region 2 (UK/Europe) DVDs as I wasn't sure if any other disc regions were compatible with my DVD player/plasma screen....
Make: Yamaha
Model: DVD S540
Can I play Region 1 DVDs on this player connected to a standard UK plasma screen TV (Hitachi 32PD5000)?
Thanks,
Chris
Old 05-02-2006, 2:52 PM   #2
Senior Moderator
LV426's Avatar
42,401, Level: 50
Points: 42,401, Level: 50 Points: 42,401, Level: 50 Points: 42,401, Level: 50
Activity: 37.1%
Activity: 37.1% Activity: 37.1% Activity: 37.1%
Thanks: Gave 1,530, Got 1,592
It won't have been supplied MultiRegion. Depending on where you bought it, it might have been modified for you. Otherwise, you may need to get it modified. I suspect it may be done using a specially coded remote control.
So, you could take the risk on the disc - or just borrow an R1 title from someone. Either way, you should get it "fixed" if necessary. Although it's not listed (yet?) you could try http://www.dvdchips.co.uk/
Old 05-02-2006, 3:59 PM   #3
8,991, Level: 22
Points: 8,991, Level: 22 Points: 8,991, Level: 22 Points: 8,991, Level: 22
Thanks: Gave 0, Got 16
Originally Posted by jchrishall2000
Hi ,
Make: Yamaha
Model: DVD S540
Thanks,
Chris
http://www.videohelp.com/dvdhacks.ph...amaha+DVD+S540
Old 05-02-2006, 5:04 PM   #4
Senior Moderator
LV426's Avatar
42,401, Level: 50
Activity: 37.1%
Originally Posted by LV426
...I suspect it may be done using a specially coded remote control....
Or, even, it's own remote and a secret key combination. Sorry about that; try the hack.
Old 05-02-2006, 9:25 PM   #5
4,820, Level: 16
Yes but...
Yes but...
I use a One4All Remote Control - er, will this still allow me to hack like this?
Ta,
Chris
Old 05-02-2006, 9:33 PM   #6
7,383, Level: 20
Points: 7,383, Level: 20 Points: 7,383, Level: 20 Points: 7,383, Level: 20
Thanks: Gave 18, Got 38
Yes but...
Ta,
Chris
I presume you must still have the original remote control though? Use the original remote to do the hack, then continue using your one4all as normal.
Powered by
 Latest popular product prices
Toshiba SD5010
7 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
9 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Samsung BD-D5500
8 prices from
 £114.95 Click to show/hide the offers
 Updated February 12th at 4:30am. Prices include delivery.
