Originally Posted by marty34 New forum member here so hi guy's
Quick question,I've got a pioneer 868 DVD player which I think is brilliant,but I recently saw a 989 in action and I thought it knocked spots off my 868,I've recently asked a reliable retailer about upgrading to the 989 but he thought it would be a poor upgrade option what do you guy's think? |
Hi There,
If you're considering the 989, maybe try and get a home demo with your screen and test side by side and go though your DVD collection.
Be careful about viewing on a new LCD HD TV as this alone will look better than many CRTs as the LCD will upscale to the panel resolution.
So what I'm saying is test both players on the same screen, so you have a point of reference. If the dealer will not permit a home review take your 898 to the dealer showroom and compare on the same screen.
I tested the 989 recently and the dealer peformed the demos on the same screen as mine, Tosh 58 series.
Hope this helps, you can read reviews to give you an idea and I do think the Pio 989 is the best one in this price bracket, but it's best to test and draw your own conclusions as every player will have strengths are weaknesses.
Regards,
Mike Paul
