Denon 1920, any probs?
Old 12-12-2005, 11:49 AM   #1
Blue.Rocket's Avatar
8,679, Level: 22
Points: 8,679, Level: 22 Points: 8,679, Level: 22 Points: 8,679, Level: 22
Thanks: Gave 4, Got 29
What if any probs have you with the Denon 1920.?
Old 12-12-2005, 5:09 PM   #2
2,733, Level: 12
Points: 2,733, Level: 12 Points: 2,733, Level: 12 Points: 2,733, Level: 12
Thanks: Gave 3, Got 3
Theres a few threads about regarding different problems, mainly lip sync probs when using DTS and some kind of locking up error when pausing and resumeing.
I've had my 1920 for about a month know and must have watched about 15 or 20 films.
I've yet to experiance any of the porblems that other people have complained about, but i have made sure that i have used quality connect cables, whether this has any bearing im not sure.
Old 12-12-2005, 5:41 PM   #3
Geordie Bry's Avatar
4,767, Level: 16
Points: 4,767, Level: 16 Points: 4,767, Level: 16 Points: 4,767, Level: 16
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 120, Got 41
no probs with mine
Old 12-12-2005, 8:45 PM   #4
4,620, Level: 16
Points: 4,620, Level: 16 Points: 4,620, Level: 16 Points: 4,620, Level: 16
Thanks: Gave 10, Got 12
no probs whatsoever, it is a great player.
Old 12-12-2005, 10:25 PM   #5
4,817, Level: 16
Points: 4,817, Level: 16 Points: 4,817, Level: 16 Points: 4,817, Level: 16
Thanks: Gave 5, Got 0
Only had one problem and that it was losing the picture with my Hitachi 7200, it was a problem with the HDMI cable, had this changed and the problem was cured.
Old 13-12-2005, 12:41 AM   #6
8,679, Level: 22
Thanks to all for your input, . I kinda think this is the player for me, now i have to find a multi region..
cheers
Old 13-12-2005, 1:38 AM   #7
BUGANNA
Posts: n/a
Sony NS92 !
better than Denon in every aspect
cheaper too.......
Old 13-12-2005, 4:35 PM   #8
Bat-man's Avatar
5,839, Level: 18
Points: 5,839, Level: 18 Points: 5,839, Level: 18 Points: 5,839, Level: 18
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 37, Got 139
None - so far.
Old 13-12-2005, 4:48 PM   #9
9,617, Level: 23
Points: 9,617, Level: 23 Points: 9,617, Level: 23 Points: 9,617, Level: 23
Activity: 11.7%
Activity: 11.7% Activity: 11.7% Activity: 11.7%
Thanks: Gave 20, Got 47
Sometimes get a slight lip-sync issue but only noticed it on a few discs, couldn't say for sure whether they were all DTS or not. I do tend to look for it rather than notice it. My Dad has never mentioned any lip-sync problems with his.
I've had the player fail to power up once due to the stop/resume problem. Reset it by turning it off at the mains and it came back on OK, again my Dad hasn't had a problem with his.
On the plus side the 1920 gives a stunning upscaled HDMI picture and the sound reproduction is superb. The sound reproduction was the main reason I went with the Denon rather than the cheaper Samsung and Toshiba HDMI models.
I got both of ours from www.petertyson.co.uk but they have recently increased the price from £199 to £239. Maybe worth waiting until after Christmas.
Lee
Old 13-12-2005, 5:09 PM   #10
8,679, Level: 22
Lee
Thanks for the feed back Lee, Interesting as you are using the same TV as I , I am keen to get a new player and was drawn to the Sony 92, but then could'nt find one, so felt the Denon may well be the answer, and sure perhaps after christmas there will will be some good deals.
seasons greetings.
Sony KDFE50A12U, Pioneer VSX-D1011, Pioneer DVD 717, Mission 734 floorstanders , Mission 73 centre , 701 rear, REL Q100E Sub,
Panasonic DMR ES30V multi region Video/DVD recorder, Sony mini Disc recoder/player
Old 13-12-2005, 11:17 PM   #11
2,867, Level: 12
Points: 2,867, Level: 12 Points: 2,867, Level: 12 Points: 2,867, Level: 12
Thanks: Gave 0, Got 2
I had trouble with the deinterlacing not working properly when using HDMI (this player doesn't support interlaced modes over HDMI). Movies were OK, but interlaced TV material (e.g. Red Dwarf, Futurama, etc) would produce interlacing artifacts such as mice teeth and juddering. I also had lip-sync problems. The handset is really nasty, too. I ended up sending the player back. Fortunately, Peter Tyson were really good about it.
Old 13-12-2005, 11:26 PM   #12
golden phoenix's Avatar
12,827, Level: 27
Points: 12,827, Level: 27 Points: 12,827, Level: 27 Points: 12,827, Level: 27
Activity: 17.4%
Activity: 17.4% Activity: 17.4% Activity: 17.4%
Thanks: Gave 315, Got 346
Hope i dont have any probs, due for delivery tommorrow, already have it in my sig below...see
Old 13-12-2005, 11:32 PM   #13
2,867, Level: 12
Well, good luck, I suppose!
Old 14-12-2005, 3:50 AM   #14
8,679, Level: 22
Let us now how you find it..
Old 14-12-2005, 7:32 PM   #15
16,655, Level: 31
Points: 16,655, Level: 31 Points: 16,655, Level: 31 Points: 16,655, Level: 31
Activity: 1.0%
Thanks: Gave 1,218, Got 968
Hi there
Had mine for about 3 months now and haven't had any problems with it and am very pleased with it.
Cheers Holo
Old 14-12-2005, 7:33 PM   #16
ribz-lfc
Posts: n/a
I'm looking to purchase the denon 1920 but i've been reading on this forum that there are issues with lip synching. Does anybody know if this is an issue and if there is a solution to it, as reading the forums nobody has actually come back with the solution.
Any help with this would be great, as i'm looking to purchase this player
Old 15-12-2005, 12:58 AM   #17
Barkhall
Posts: n/a
Noticed you have a pioneer 717 blue rocket and the Sony 50". I have just got my Sony today, and have also got the pioneer 717 but have not yet connected the 717. I am thinking of buying an HDMI player and have been thinking of the Samsung HD850 or the Tosh SD350, but now have been drawn to the Denon since reading these posts. Is the picture quality that much better than with the 717?
Old 15-12-2005, 9:43 AM   #18
8,679, Level: 22
Hi; Have not yet made the plunge to upgrade the DVD player, so at this time cannot answer the question directly.
However reading some of the comments, the problems on new players i e Sony and Denon, seems to be coming via the HDMI, so i feel if i purchased a new player and the HDMI let me down i would use the RGB , which as i am told is better than the S video connection.
At the moment I am running my 717 s video link straight to the TV whilst the audio from the 717 runs into my amp, and have to say its a great picture, and realy wonder if i can better it. But certainly I would suggest quality cables at all time ,to get the very best...
Logiclee who uses the Denon along side the Sony 50" seems to find it ok, and has made some good comments on the forums, the subject is also brought up on the Projection section here,
http://www.avforums.com/forums/bt-vision/
Personaly I am going to wait till after xmas and see if there are any bargains about..
Old 15-12-2005, 10:41 AM   #19
Barkhall
Posts: n/a
Thanks Blue Rocket, I will order myself an SVHS cable today from Cable Universe as they have various qualities at good prices. I will order the premium ones and see what happens. I have an optical connection from my AV amp to the 717, so that should take care of the audio side. My main irritation with the 717 is that it does not play copies of DVDs or CDs, so I use a Wharfedale DVD player for CDs, and I actually find the audio is better than the Pioneer.
Old 15-12-2005, 2:34 PM   #20
8,679, Level: 22
Interesting, my multi region 717 plays all DVDs and CDs including most CD-Rs, but would like to upgrade to SACD...
My latest viewing DVD was Polar Express, watching that through the 717 Svideo was brillaint....................
Old 16-12-2005, 7:39 PM   #21
4,993, Level: 16
Points: 4,993, Level: 16 Points: 4,993, Level: 16 Points: 4,993, Level: 16
No problems for me with the Denon 1920. Great picture and superb sound. Remote looks and feels a bit cheap and nasty but does the job fine.
Only thing I was a little disappointed with is that the 2mb buffer doesn't seem to have any affect on the layer change - it's just as bad as previous players I've had. I know that you need to go to the 2910 to get 8mb and seemless layer change, but I did expect some small improvement from the 2mb.
Steve
Old 16-12-2005, 9:54 PM   #22
5,185, Level: 17
Points: 5,185, Level: 17 Points: 5,185, Level: 17 Points: 5,185, Level: 17
Thanks: Gave 2, Got 6
Did you have same problem when using component?
edit: do -> did
Old 16-12-2005, 10:35 PM   #23
Repton's Avatar
6,422, Level: 19
Points: 6,422, Level: 19 Points: 6,422, Level: 19 Points: 6,422, Level: 19
Thanks: Gave 37, Got 138
Steve
totally agree
Old 16-12-2005, 11:19 PM   #24
2,949, Level: 12
Points: 2,949, Level: 12 Points: 2,949, Level: 12 Points: 2,949, Level: 12
Thanks: Gave 2, Got 1
Just plugged mine in today, and I can only seem to get composite video (instead of RGB) out of the SCART. Can't seem to find any way to influence this in the menus. This is multi region by Super-fi, so maybe it is something to do with their hack?
Mark W.
Old 17-12-2005, 12:02 AM   #25
2,867, Level: 12
Never tried it with component. I bought the player to use with HDMI. It couldn't do that properly, so it wasn't worth keeping.
Old 18-12-2005, 3:38 PM   #26
3,457, Level: 13
Points: 3,457, Level: 13 Points: 3,457, Level: 13 Points: 3,457, Level: 13
Thanks: Gave 42, Got 5
Can anyone tell me if the 1920 upscales through component or is it only through HDMI.
Has anyone compared the two to see if the picture is better through HDMI.
I had th samsung HD950 but sold it as I couldn't see any difference between 720p through HDMI and component on my chipped xbox.
Old 18-12-2005, 4:38 PM   #27
Somersett
Posts: n/a
Originally Posted by Dogma21
Can anyone tell me if the 1920 upscales through component or is it only through HDMI. Has anyone compared the two to see if the picture is better through HDMI.
I have the 2910 and, as far as I can tell, it only upscales via HDMI/DVI. I have tried both component and HDMI and to be honest I see little if any difference betwen the two. That said, I have only just taken delivery of my new system and I am still playing around with various settings to see what gives the best picture.
Old 18-12-2005, 8:49 PM   #28
3,275, Level: 13
Points: 3,275, Level: 13 Points: 3,275, Level: 13 Points: 3,275, Level: 13
Thanks: Gave 41, Got 8
I looked into this player at my local dealer, who advised me that its brilliant for tv's upto 32" any bigger its poor. Is this true?
Old 18-12-2005, 8:56 PM   #29
2,528, Level: 11
Points: 2,528, Level: 11 Points: 2,528, Level: 11 Points: 2,528, Level: 11
Thanks: Gave 1, Got 5
Paul,
Your dealer is talking a load of codswallop. The 1920, which I have presently on trial from my dealer,shows an excellent picture on my 92" screen, via my Z4. For example, "The House of Flying Daggers" looks simply stunning. Zhang Ziyi on the other hand just looks utterly phenomenal
Old 18-12-2005, 9:22 PM   #30
3,457, Level: 13
I didn't know you could trial equipment.
Which dealer do you use?
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 12:30pm. Prices include delivery.
