HDMI Vs Component.
Old 06-12-2005, 4:57 PM   #1
4,071, Level: 15
Points: 4,071, Level: 15 Points: 4,071, Level: 15 Points: 4,071, Level: 15
Thanks: Gave 0, Got 5
HDMI Vs Component.
I have a HD ready panasonic TV and looking for a DVD player to go with it.
I was told by panasonic today that there will be no major difference between component and HDMI for picture quality - as all the panasonic DVD units are non HDMI at the moment.
Any advice from anyone who has HDMI etc !?
Ade
Old 06-12-2005, 5:30 PM   #2
AVF Hardware Reviewer
Russell.Williams's Avatar
34,278, Level: 45
Points: 34,278, Level: 45 Points: 34,278, Level: 45 Points: 34,278, Level: 45
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 745, Got 1,452
Granted, if you cable runs are short and the screen small, then you may see very little difference, but there is no reason to only buy a Panasonic players. I am running a projector via HDMI and the difference over component was quite marked. Less artifacting and a generally less noisy picture gave much cleaner results, but some reviews I have seen of various Plasmas amd LCDs prove this is not always the case, mainly due to the differing ability of displays to scale different inputs. There are very many fine players complete with both out-puts these days and it is to these I would look, if only for a touch of future proofing.
Old 06-12-2005, 5:44 PM   #3
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Hello Adrian Hughes
I'll bet you a tenner as soon as your local Panasonic shop have HDMI equipped players they'll be telling you HDMI is the connection of choice
Keep in mind HDMI is a connectivity standard - it transports Digital RGB or Digital YUV 'Component' signals; done correctly RGB over HDMI will look less noisy than YUV over an Analogue (3RCA) connection.
There is no hard and fast rules here though - your TV manufacturer may have spent more time and cost on the HDMI Input circuitry (very likely as its the new big thing) and equally on a budget DVD player/recorder the Analogue YUV circuitry may be better than the HDMI Digital circuitry.
As russ.will suggests you may want to spread your net a little further than sticking with Panasonic and have a look for yourself at Digital vs. Analogue into your TV; keep in mind when you switch from Analogue 'Component' to Digital 'HDMI' you need to have a look at what 'setting' the TV is on otherwise one Input could be on Dynamic (horrid) and the other on Cinema (much more acceptable if its a Panasonic PlasmaTV).
Best regards
Joe
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 5:30pm. Prices include delivery.
