The best Dual Progressive scan for less than £150??
Old 20-11-2005, 8:42 PM   #1
trebs
Posts: n/a
Hi all, I have only just registered here and I need advice because I have just bought a Hyundai 42 inch plasma and I need to find a good progressive player (Ive always used scart and I'm curious to connect these component cables up!) but it needs to be both PAL and NTSC. I've spent hours scouring for such a player but they only seem to be Pal OR NTSC. Or can they be firmware hacked to play all?
I'm sorry if this is a common question!
My yamada 2100 just gives me a blank screen thru component.
tia for any replies!
Trebs
Old 20-11-2005, 8:54 PM   #2
Kalos Geros's Avatar
5,711, Level: 17
Points: 5,711, Level: 17 Points: 5,711, Level: 17 Points: 5,711, Level: 17
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 4, Got 73
Are you looking for a progressive player that can be region hacked or a player that can do progressive scan with both PAL sourced films and NTSC sourced films???
Old 20-11-2005, 8:55 PM   #3
trebs
Posts: n/a
Both prefereably but I can maybe RIP the DVD to take the region from it if need be.
Thanks.
Old 20-11-2005, 8:57 PM   #4
9,144, Level: 22
Points: 9,144, Level: 22 Points: 9,144, Level: 22 Points: 9,144, Level: 22
Thanks: Gave 81, Got 36
Trebs
check these sites out, click below; prices from £45!
http://www.videohelp.com/dvdplayers?...y=Name&hits=25
http://www.pricerunner.co.uk/sound-a...2878=&a_1393=1
if you need more help, just ask!
Old 20-11-2005, 9:16 PM   #5
5,711, Level: 17
Activity: 6.1%
I think you can't go wrong with the Pioneer 380 or 585 if quality progressive scan at a good price is an issue...these babies have 108Mhz/12 bit DACs...
Old 20-11-2005, 9:21 PM   #6
5,585, Level: 17
Points: 5,585, Level: 17 Points: 5,585, Level: 17 Points: 5,585, Level: 17
Thanks: Gave 5, Got 35
How about the Toshiba 350e (£75)
http://www.amazon.co.uk/exec/obidos/...488114-8741403
Gets very good reviews, particularly for it component progressive output.
And will automatically switch between PAL and NTSC as required.
Old 20-11-2005, 9:42 PM   #7
trebs
Posts: n/a
Thanks Superseven I was looking at the Tosh here
http://www.amazon.co.uk/exec/obidos/...174264-2031834
but it says PAL progressive!
Is it definitely NTSC too?
If it is I will definitely buy it!!
thanks again
Old 20-11-2005, 10:41 PM   #8
trebs
Posts: n/a
Just read the thread on the 350 with all it's pro's and cons people say its great with component inputs so I've now ordered it !
Thanks guys!
Old 21-11-2005, 12:48 PM   #9
Krishna
Posts: n/a
Hi Guys,
Kalos Geros posted this earlier "I think you can't go wrong with the Pioneer 380 or 585 if quality progressive scan at a good price is an issue...these babies have 108Mhz/12 bit DACs..."
sorry for "hijacking" here - but just curious - does anyone know which is better: 108Mhz/12bit (like in the new Sony NS92) Video DACs or 216Mhz/11bit (like in the Panasonic DVD-S97) ?
Old 21-11-2005, 1:01 PM   #10
9,144, Level: 22
Trebs
what about the samsung hd850 upscaling player £85 which will upscale via component, is your screen compatible??
Old 21-11-2005, 1:48 PM   #11
Conspicuous Member
PJTX100's Avatar
16,232, Level: 30
Points: 16,232, Level: 30 Points: 16,232, Level: 30 Points: 16,232, Level: 30
Thanks: Gave 402, Got 566
Do not touch Samsungs for component, you'll find discussion on this forum of them putting dumbing capacitors in the component signal path to make it look poor vs the DVI/HDMI output....PJ
Old 21-11-2005, 1:59 PM   #12
6,493, Level: 19
Points: 6,493, Level: 19 Points: 6,493, Level: 19 Points: 6,493, Level: 19
Thanks: Gave 1, Got 6
Get yourself a Pioneer DV-575 - its performance via component isn't bettered unless you spend ~3 times the cost...
Old 21-11-2005, 6:21 PM   #13
shodan's Avatar
8,221, Level: 21
Points: 8,221, Level: 21 Points: 8,221, Level: 21 Points: 8,221, Level: 21
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 206, Got 579
Try the componant out on your DVD player first but before you do when the scart is still plugged in, make sure through the menu that the dvd player is set to output componant, then plug the cables in and select that input on your display.
Old 21-11-2005, 11:31 PM   #14
9,144, Level: 22
what upscaling player would you recommend via component?
Old 22-11-2005, 4:39 PM   #15
5,711, Level: 17
Activity: 6.1%
jamiev...there is no other player that I know of beside Samsung that upscales via component...LG DVX9900H does upscale via comp, but only the discs that are not copy-protected...ppl say however that the Samsung outputs upscaled component with higher quality from SCART's RGB pins so you may try getting a SCART-to-RCA adpater...
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 13th at 6:30am. Prices include delivery.
