Now the subtitles I can help you with.
I think it is under the first menu setting.
I think it is headed up 'Subtitle'? Switch to 'No'
I'll double check tonight to make sure.
I have no idea why they would set it to default. Who ever design part of this player must have thought "How can I make it as awkward to start using this player as possible?!"
Although as useful as subtitles are most people do not require them on as default.
Also make sure you switch the sounds to Bitstream and not PCM else you won't get proper 5.1 Digital sound
Can anyone else help on my original problem with sound?
The Toshiba website is utter rubbish.
