| Pioneer DV565A component/progressive scan problem
I have a Pioneer DV565A dvd player, and just bought a Panasonic TH42PA50 plasma TV. I try to use Monster Video2 component cable to connect the two. On the dvd setup menu I choose to use component/progressive scan. This works fine until the next time I want to use the dvd player. Then the screen is all black (on the component channel). I then have to enter the dvd player setup menu again, and set the component output to interlaced and then back to progressive again. Then it works until I turn the player on and off. Then it is the same problem again...
This is really annoying, and I found a another posting on a norwegian forum where a guy had the exact same equipment and same problem. Unfortunatly nobody had replied to the posting.
Now I use component/interlaced, but I want to use progressive... Has anyone experienced this before, or have any tips what I might try? Is there for example a firmware upgrade for the player??
regards, Anders
