Originally Posted by Neil Fellows ...not me exactly, but type Pixmania into the search and you will get a good idea of what kind of company they are. One example - they actually charge you for a basic 12 month warranty, otherwise if it breaks down 2 hours after purchase you've had it. They also put extra things into your shpping basket (they added about £12 to mine) while you are purchasing without asking. And it's French. |
Yes they do try to add a couple of items to the basket but they can be removed - naughty all the same.
Didn't read in detail about the warranty but either way the manufacturer covers the item for 12 months and as it's a French company it may be easier dealing with the UK Samsung contact if there are probs. I think the warranty they charge for is an "enhanced" service, or something like that.
They were pretty quick shipping the 745 to me, it was a decent price, and it was extremely well packed. The only complaint is the plug - they should make it clear it's a euro spec and should include an adapter FOC.
...PJ
