Originally Posted by PJTX100 Hi Patrick.
What were you feeding the DVI into and how long was the cable?
Thanks...PJ |
I have a Thomson 27LCDB03 TV and use the standard 1.5m DVI cable that came with the 745. Picture is spot on (apart from blacker than black but this isn't really an issue for me). Overall picture quality is stunning. There's no macro blocking that I can see, colour reproduction is superb and there's almost zero picture noise.
It does tend to show up poorly encoded discs though - especially those TV series where they've crammed 4 hours onto a DVD9!
Patrick
