Denon DVD-2910 MR firmware ESS-6720-8
Old 06-03-2005, 11:33 AM   #1
5,674, Level: 17
Points: 5,674, Level: 17 Points: 5,674, Level: 17 Points: 5,674, Level: 17
Posted on German AV forum www.hifi-forum.de. Credits go to the original poster Dierterle.
Download link can be found in this thread: DVD-2910 6720-8 Codefree.
Rename file to zip (i.e. remove .jpg extension), unpack, burn.
Already tried that new MR firmware. It works flawlessly on my 2910.
Cheers,
Digitalsurfer
Old 06-03-2005, 12:11 PM   #2
3,490, Level: 13
Points: 3,490, Level: 13 Points: 3,490, Level: 13 Points: 3,490, Level: 13
Thanks: Gave 1, Got 1
Hi:
it seems that the bandwith quote for the place where the file is sotred has been exceded. Can you please e-mail me your copy to jfr2003@nospam.sapo.pt ? (remove the nospam.)
Regards,
J. Rosado
Old 06-03-2005, 12:44 PM   #3
5,674, Level: 17
You got mail.
Old 06-03-2005, 2:19 PM   #4
6,090, Level: 18
Points: 6,090, Level: 18 Points: 6,090, Level: 18 Points: 6,090, Level: 18
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 20, Got 21
don't suppose you can send a copy to r.tarn@barnsley.org i can't seem to upgrade my firmware no matter what i do
cheers
Rob
Old 06-03-2005, 5:48 PM   #5
3,490, Level: 13
cheers
Rob
You got mail. Be aware that this firmware is for the 2910 (not the 3910).
Regards,
J. Rosado
Old 06-03-2005, 7:15 PM   #6
6,090, Level: 18
Activity: 0.5%
Can anyone tell me why no matter what i do burning to CD or DVD i can't get the firmware to work? My player says loading then stop and thats it. In fact with a DVD it syas stop but spins up the disc every few seconds. All the setting are as i have been told and am using nero
Heeeellllllppppppp
Old 06-03-2005, 7:16 PM   #7
6,090, Level: 18
Activity: 0.5%
PS i haven't received that email digitalsurfer, could you resend it
Rob
Old 06-03-2005, 11:00 PM   #8
3,490, Level: 13
rdt123:
You just have to burn a cd-r/rw at the lowest speed possible, in mode1, ISO9660, disc at once, with the file that's inside the zip on the root. have you receiveid the e-mail allready?
Digitalsurfer:
Any idea of what this firmware corrects?
Regards,
J. Rosado
Old 07-03-2005, 7:43 AM   #9
6,090, Level: 18
Activity: 0.5%
hi jrosado, i have all the setting set as youpoint out but in the root i just get 0 on the disc and nothing happens
annoying
Rob
Old 07-03-2005, 9:36 AM   #10
6,434, Level: 19
Points: 6,434, Level: 19 Points: 6,434, Level: 19 Points: 6,434, Level: 19
Could some kind person please email me the -8 firmware
Many Thanks
martin@smltechnologies.com
Old 07-03-2005, 10:01 AM   #11
jackb
Posts: n/a
Would appreciate anyone who can email me the firmware at yathlee@yahoo.com
Thanks!!!!!!!!!!
Old 07-03-2005, 10:16 AM   #12
jackb
Posts: n/a
annoying
Rob
rdt123, I have updated the ealier version twice without any problem What cd burning software do you use? I will try to help you if you provide me with the detail.
Also, if you don't mind, please email me the firmware as well. I can't download it due the limit set at the hosting site.
Old 07-03-2005, 10:45 AM   #13
5,674, Level: 17
Firmware emailed to rdt123 (again), martin1234567 and jackb.
Maybe a kind person could host the firmware file?
Old 07-03-2005, 6:19 PM   #14
dex dex is offline
7,630, Level: 20
Points: 7,630, Level: 20 Points: 7,630, Level: 20 Points: 7,630, Level: 20
Could you email it to me please and I'll host it.
Email HERE
Old 07-03-2005, 6:20 PM   #15
6,090, Level: 18
Activity: 0.5%
Hi digitalsurfer,
Sorry, it was our mail server playing up. Have it now. I'm using nero. I set mode 1 and ISO 9960 only. Burnt at lowest speed to both CD-R and DVD+R
No luck yet
Old 07-03-2005, 7:28 PM   #16
6,090, Level: 18
Activity: 0.5%
Thanks so much,
it worked and i now have DVD-A menu's and audio with video! Brilliant
Rob
Old 07-03-2005, 11:08 PM   #17
dex dex is offline
7,630, Level: 20
Thanx for the firmware DigitalSurfer
Anyone else who needs it can get it here: DVD-2910_6720-8_codefree.zip
Old 08-03-2005, 7:18 AM   #18
Beastie Boy
Posts: n/a
Email HERE
You have mail.
Apologies for the filesize, I'm not allowed to send zip files from work.
Cheers, Beastie.
Old 08-03-2005, 11:16 AM   #19
5,585, Level: 17
Points: 5,585, Level: 17 Points: 5,585, Level: 17 Points: 5,585, Level: 17
Thanks: Gave 2, Got 1
I know it has been listed before - but I can't find it anymore.
Can a kind soul list the steps required to update the 2910 firmware?
Thanks!
Old 08-03-2005, 11:37 AM   #20
Beastie Boy
Posts: n/a
Here is a pdf that came with a previous release. Ignore the firmware version number referred to within.
Cheers, Beastie.
Old 08-03-2005, 11:52 AM   #21
5,585, Level: 17
Beastie Boy,
Many thanks!!!
Old 08-03-2005, 9:36 PM   #22
5,585, Level: 17
I tried the upgrade this evening and it worked a treat!!!
Thanks to Digitalsurfer for sharing the firmware, Dex for hosting the firmware and to Beastie Boy for sharing the official installation instructions from Denon. It gave me more confidence to undertake the upgrade on my 3 week old 2910.
The difference in Version 8 over Version 4:-
(i) DVI output is now brighter and with higher contrast. Previously, DVI was noticably darker;
(ii) Green tint issue over DVI more or less resolved. This is still a tinge of green tint but easily overcome with the hue adjustment on the TV
(iii) consequently much better PQ over DVI!!
(iv) the DVD-A menu is now visible over DVI. It wasn't before the upgrade
(v) for SACD playback, the amount of noise is very much reduced at very high volume playback. No difference with DVD-A. Previously, noise levels was quite high at very high volume. I am talking about >85% levels here!
Overall, very pleased with the upgrade . Will recommend those who have not upgraded to do so. The most difficult step in the process is to burn the file at ISO and Mode 1 and at the lowest speed. My software has a default of Juliet+UDF. To be doubly sure, I made sure that the CD-R was verified after burning.
Old 10-03-2005, 7:16 PM   #23
OregonWomble
Posts: n/a
I had a region 1 ntsc player, and the pal/ntsc menu was disabled, and the pal/ntsc button on the remote would not work either. I installed the version 4 code free patch, and it would play all regions, but it would not output a DVI signal with a PAL disk.
Has anyone purchase a region 1 machine that would output pal or ntsc, or are all the machines sold in the US ntsc only?
Will the version 8 codefree firmware fix this problem?
Old 15-03-2005, 2:55 PM   #24
mbaxevan
Posts: n/a
You can only change PAL < -> NTSC when no disc is inserted (or tray is open) or try to set your TV type to MULTI in the Video Setup Menu.
Old 16-03-2005, 8:43 AM   #25
4,732, Level: 16
Points: 4,732, Level: 16 Points: 4,732, Level: 16 Points: 4,732, Level: 16
Talking
Hi everybody,
I upgraded my european 2910 to version 8 and it worked great.
Old 16-03-2005, 1:27 PM   #26
Duffers0
Posts: n/a
Guys
You seem to having some success with the update, great.
My recent (less than a month) purchase was updated in Sevenoaks to multi region at the point of sale.
I asked what firmware version but the salesman had little idea.
Can someone publish the button pressing sequence for firmware number to appear on screen.
Where update 8 has been successful can you confirm it maintains mulit region.
Strange but my multi region updated in the shop is described as region 1-6 is that full multi region??
Bit nervous but I might give the firmware update a go, though I have been very happy with the player since I bought it.
Old 16-03-2005, 1:36 PM   #27
mbaxevan
Posts: n/a
Does any know which bugs this firmware (-8) fixes and/or does it add any additional features/bugs? Or is it just a MR version of the -7 firmware?
However I have succesfully "flashed" my player with the -8 firmware bacause I needed the MR feature. Worked just perfectly.
Still it would be nice to know more...
Old 16-03-2005, 2:56 PM   #28
4,732, Level: 16
Duffers0, the pdf file in message #20 explain everithing you need to know to update and show the version number
Old 16-03-2005, 5:18 PM   #29
Duffers0
Posts: n/a
Outputs read
DSP 6770
ESS 6720 -4
Make Day 831
DRV 030825
Systems 6768 -2
Guess the ESS reading means firmware version 4, right??
What does the other outputs mean??
Old 25-03-2005, 2:01 PM   #30
Top-Trump
Posts: n/a
Thumbs up Nice
Since I had to register to access the info I thought I'd post something in celebration!
The pdf instructions are very easy to follow and I burnt a firmware cd with no problems. The update worked fine too and only took a minute.
I've just bought House of Flying Daggers R3 DTS (only 8.99 from cdwow with discount - thanks to this forum) and this spurred me on to finally do the update after watching the various firmware posts since buying it last November.
All is fine and I'll be watching it tonight.
Powered by
 Latest popular product prices
Toshiba SD5010
7 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
9 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £89.95 Click to show/hide the offers
Samsung BD-D5500
8 prices from
 £114.95 Click to show/hide the offers
 Updated February 11th at 8:30am. Prices include delivery.
