pioneer DV575A default output
Old 05-03-2005, 6:34 PM   #1
applevenus
Posts: n/a
I've got a feeling this is a simple fix but for the life of me I can't figure out what I'm doing wrong.
Setup is Pioneer DV575A connected via fully wired scart to Select 320+ CRT projector
When I powerup the DVD player the projector switches to the S-Video signal via the scart and I have to manually change it to the RGB input (via scart).
Being a geek I'd prefer this to happen automatically.
I'm guessing that the player is sending signal to the Seleco telling it to go to s-video.
How can I change this so that the player defaults to the RGB output ?
Old 08-03-2005, 10:40 PM   #2
RJB RJB is offline
2,517, Level: 11
Points: 2,517, Level: 11 Points: 2,517, Level: 11 Points: 2,517, Level: 11
Check what you have set for "AV connector Out", as listed on page 35 of the Operating Instructions, in the Video Output settings. Sounds like you have S-Video selected.
Old 12-03-2005, 3:04 PM   #3
applevenus
Posts: n/a
double checked - it's set to RGB
Old 14-03-2005, 12:19 AM   #4
18,481, Level: 32
Points: 18,481, Level: 32 Points: 18,481, Level: 32 Points: 18,481, Level: 32
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 123, Got 99
I have a similar(?) problem with my 575.
I cannot select RGB SCART (only video and S) with component (i) selected.
So I can't use RGB SCART and component at the same time.
Do you have component selected?
Old 23-09-2005, 12:28 PM   #5
av2diefor
Posts: n/a
Did anyone work a way round this?
I have tried to force component out and it wont let me highlight it.
Is there a quick fix?
Old 23-09-2005, 4:35 PM   #6
av2diefor
Posts: n/a
Any kind soul point me in the right direction?
Spoke to RS and there is a workround but they cant remember
Old 24-09-2005, 12:06 AM   #7
7,607, Level: 20
Points: 7,607, Level: 20 Points: 7,607, Level: 20 Points: 7,607, Level: 20
Thanks: Gave 0, Got 31
Got the exact same problem;
Just got a new Pioneer 575 and a Hitachi Plasma
However, I cannot get the Pioneer to output a component/progressive scan signal to the Plasma - the option is greyed out
When I connect an older Limit 9000, component and progressive are there and work perfectly.
Any ideas about the Pioneer??
Old 24-09-2005, 1:28 AM   #8
4,129, Level: 15
Points: 4,129, Level: 15 Points: 4,129, Level: 15 Points: 4,129, Level: 15
Thanks: Gave 0, Got 2
Make sure the scart output isn't set to RGB, I think. Scart out = Video then you should be able to select component out and select progressive scan, from memory, I may be wrong, I have slept since last using one of these......
Old 24-09-2005, 5:55 AM   #9
av2diefor
Posts: n/a
Brock, i know what your saying, its easy when your doing setups but after a few days it all goes.................
There is a fix, i think its as simple as holding the power button down, well along those lines.
Old 24-09-2005, 8:15 AM   #10
7,607, Level: 20
brock_landers - PERFECT
Worked a treat.
I spent till 1am last night trying to figure that out
Thanks very much
Old 25-09-2005, 7:35 AM   #11
av2diefor
Posts: n/a
Zorro,
i think i am missing something here.
Still no go for me,
575, main menu
initial settings
video out
tv =16.9
component =progressive
av out=video
Old 25-09-2005, 10:10 AM   #12
7,607, Level: 20
Yep - that was they way it worked for me
I connected it by both component and scart leads.
I then went into the initial settings menu and i had the av out as RGB.
I changed that to video and the component option became available, allowing me to highlight progressive
try both leads at the same time - worth a shot
Old 25-09-2005, 11:16 AM   #13
6,775, Level: 19
Points: 6,775, Level: 19 Points: 6,775, Level: 19 Points: 6,775, Level: 19
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 0, Got 16
You can not use progressive and RGB at the same time.
You need to either change RGB to S-Vid or Video to use progressive, or change progressive to interlaced to use RGB.
It's all in the manual.
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
6 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
9 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
5 prices from
 £94.95 Click to show/hide the offers
Panasonic DMP-BDT110
7 prices from
 £99.99 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
 Updated February 12th at 11:30pm. Prices include delivery.
