| Pioneer 575 / 676 - help with Audio Set up.
I got a new Pioneer DV-676A player (supports DVD-A, SAVCD, DIVX)
I think this is equivalent to the 575A in Europe/USA.
I connect the digital audio out from the Pioneer player to a Yamaha AV Receiver(RX-V795) via a Co-axial connection.
Can someone please help me with the Audio output settings on the Pioneer.
Should the Dolby Digital Out be -> Dolby Digital or >PCM ?
Should Linear PCM out be down sample on or off ?
Should MPEG out be PCM ?
Just to clarify the only audio out I have from the Pioneer is digital co-axial to a Yamaha amp.
I’ve tested Dolby Digital and it works fine on my 5:1 set up.
I bought this new pioneer partly because I use it as my main CD player and want to ensure the *best* quality CD playback in this set up
Would I get better CD playback if I connected the left / right speaker settings individually to the Yamaha amp rather than via the digial co-axial ?
Thanks in advance.
