Originally Posted by skip hi edinburgh could you just give some advise if possible. totally new to all this , just stepped up to the tosh 46 dlp and was advised to get a hdmi dvd player to get use of its full potential. s97 arrived today and a bit worried i am going to have probs setting up. dont want to take out of box if going to give myself major headaches, i have got 7 days to send back. is it just straight forward as to connect hdmi dvd to hdmi tv and set dvd to auto and tv to hdmi, or more complicated.and what is firmware updates and do i need to do it. cheers |
Hi, setting up is easy, just use HDMI-HDMI lead included in box. You need to go to the set up menu and set HDMI 'on', then it will be ready.
The manual is ok, but could have been set up a bit better. Put it this way, I'm not an expert and find it pretty straight forward. I don't know your plasma, but for mine when I turn the dvd player on, i just change the input channel on my plasma remote, and get the picture.
The player is already set up as 'auto', however you can change the settings to your hearts content, but I find auto is fine, and I jig my plasma settings about for my best picture.
THe firmware updates are foreign to me. The S97does have some macro issues, and by all accounts these fix/help this. I'm off today, and am about to download it onto disc and see what happens.
cheers
