Help! I need a new DVD player
Hi, Guys. This is my first post here so be gentle!
I bought a 42" plasma before xmas (Hyundai HPTD4201S) and I've got it hooked up to a Toshiba SD240E through component cables with the progressive scan enabled. The problem, not to put too fine a point on it, is that the Tosh is completely crap. PQ is ok but it's extremely picky about playing anything but perfect original discs and will skip and jump with most dvd-r's or slightest scratches. Also sometimes whilst playing a movie the remote and front panel buttons will be rendered useless forcing me to reach behind and pull the plug. Anyhoo, I'm sick of it and want a change even though it's less than 2 months old.
I've been looking at the Denon dvd-1910 as a replacement (Through the DVI which is currently used for my PC) and wondered if anyone had any thought or suggestions? Will I notice a difference between DVI and my current progressive scan setup? Is the Denon any good or are there better (sub £200) DVD players available?
Cheers for any help you can give
