Best cheap player for inlaws.
Old 21-07-2012, 10:41 PM   #1
Scooby2000's Avatar
Thanks: Gave 1,679, Got 2,157
Hi all as above looking for a decent bluray player, sub 100 would be good. I like Samsungs and Panasonic players myself but they tend to be more. Good few on RS site but have no idea how good they are.
Old 22-07-2012, 12:08 AM   #2
Scooby2000's Avatar
Any cheap players that do a reasonable job of upscaling DVDs?
Old 22-07-2012, 7:06 AM   #3
skk3's Avatar
Thanks: Gave 92, Got 137
Try ASDA for the Sony BDP-185...
Scooby2000 (22-07-2012)
Old 22-07-2012, 8:30 AM   #4
Scooby2000's Avatar
Thanks I'll take a look.
Old 22-07-2012, 9:27 AM   #5
skk3's Avatar
Or here MR for DVD with 8 free Blu-rays; more expensive though.
Old 22-07-2012, 9:32 AM   #6
Thanks: Gave 19, Got 335
The Phillips players offer a lot of bang for buck, have simple remotes and for less than £100 you can pick up the 5000 series 3D model with WiFi connection, USB playback and lots of smart apps.
An oveerlooked model that does not do a bad job. May not be best in class for picture, but a user friendly player suited to casual viewers.
Found this one Philips BDP5200/05 3D Blu-ray Player with USB 2.0 and Built In Wi-Fi on eBay! on that auction site for example.
Old 22-07-2012, 9:46 AM   #7
Scooby2000's Avatar
Thanks chaps, looking at the LG BD 670 too, good review and dropped in price. Or the Sony BDP 480 maybe.
Old 22-07-2012, 1:21 PM   #8
Scooby2000's Avatar
Went for a Panasonic BD75 from Currys for 78 quid, had to buy today so I can set it up for them. The Sony 185 was £80-90 and looked a bit cheap and nasty, also needed a display.
Old 23-07-2012, 6:32 AM   #9
skk3's Avatar
Glad you're sorted...
