Originally Posted by neo_2009 Hi Smarty.
If you do have the time and the patience, could you please compare the sound quality when using the panasonic analog outputs (DTS HD), versus using the digital output to the Arcam (1,5 Mb DTS Core). |
Right, finally managed to do some testing and comparison of DTS HD (over analogue) v DTS core (over optical). I've set my amp (Arcam AVR300) so that the DVD input picks up the optical signal from the BD Player and Multichannel input picks up the analogue signal. I used Jurassic Park and TinTin as test BluRay discs. Switching from DVD to Multichannel on the amp on the same scenes I have to say I really struggled to hear any difference, especially on the Jurassic Park disc (maybe because it's a relatively old film now?).
On TinTin, I would say the DTS HD sound over analogue was possibly slightly more "open" sounding. A bit more immersive I guess. However, remember this is after a lot of switching back and forth and really trying to hear a difference. If I just had the optical link and listened to DTS Core I'd still be very happy although I suspect I'd be thinking 'I wonder what the HD sound would be like' if I had say the BDT320 instead.
I then tried the DVD version of TinTin over optical and analogue. I think I actually prefer the sound over optical, letting the Arcam do the decoding rather than the BDT500.
Having said all that, the BDT500 wasn't much more than the 320 and you get 2 HDMI outputs plus the analogue outs and optical plus coax. I suspect if you were going to be using it as a CD player as well then the sound of the 500 would be better (I use an Arcam CD player which does sound better than the 500, but then it should).
Hope that helps. Basically, I think you'll be impressed with the sound regardless of whether it's DTS core or HD.
