An NTSC signal is probably going to give you optimum results. You get an NTSC signal by having BOTH:
a) an NTSC capable player - all those on the sale in the UK are both NTSC and PAL
b) exclusively NTSC discs.
All discs sold in the UK (with a tiny handful of exceptions) are PAL. The thing to most certainly avoid doing, is converting a PAL source disc to NTSC for output. Few players do this anyway, but those that do, degarde the signal to a much greater extent than the downscaling in the Plasma screen will.
So, you will need a Region 1 - capable player (eg multi-region), and to buy all your DVDs from US/Can importers (region 1). You could also buy Japanese discs, which are NTSC, region 2, (in which case your player does not need to be multi-region) but these are typically expensive and arguably best saved for instances where Japan enjoys a better/extended/superbit/whatever version that the rest of the world doesn't have.
