Sony BDP-S380 (Supports NTFS over USB)
Old 31-03-2011, 12:41 PM   #91
Thanks: Gave 30, Got 22
There was an update to the iPhone media remote app the other day which said it now supported more devices. Could it be that?
Old 31-03-2011, 2:01 PM   #92
Paul.B2's Avatar
Thanks: Gave 184, Got 190
Maybe, but not sure why it wouldn't work on either iPhone or android phones.
Sent from my iPhone using AVForums
Old 01-04-2011, 11:44 AM   #93
Thanks: Gave 1, Got 0
£99.99 plus Tron free on play today
its in the title
Old 01-04-2011, 1:07 PM   #94
Thanks: Gave 2, Got 0
Advice please!
I'm just about to buy one of these to replace the SD player on my home theatre system. What's the best way to hook it up so that I get surround sound?
Old 01-04-2011, 2:17 PM   #95
Paul.B2's Avatar
Does your Amp have HDMI inputs and/or Digital Coax? Either of those connections will give you surround sound.
Old 01-04-2011, 2:37 PM   #96
Definitely has HDMI (which I assumed would go to the telly) and I can check for digital coax. Thanks for your post.
Old 01-04-2011, 2:40 PM   #97
Paul.B2's Avatar
If there's only 1 HDMI socket, that will be an output. You need an input socket too.
What model of Amp is it?
Old 01-04-2011, 2:46 PM   #98
Mo Better Blues's Avatar
Thanks: Gave 17, Got 44
Originally Posted by ctreadwell4nd8 View Post
its in the title
Yep, at that price, plus the film, Play now have my order.
That makes 6 blu-ray players in the house!
Madness
Old 01-04-2011, 3:10 PM   #99
Ah - it's an all in one system - Samsung. The DVD player doesn't work, so I thought this Sony would be an excellent replacement.
Old 02-04-2011, 10:31 AM   #100
mentm's Avatar
Thanks: Gave 80, Got 378
It probably has an optical in you can use for 5.1, but may be worth thinking about getting a new surround sound.
Old 02-04-2011, 10:33 AM   #101
Paul.B2's Avatar
Don't forget that the 380 has no optical out though.
Old 02-04-2011, 11:04 AM   #102
mentm's Avatar
Really!! Didn't realise the s370 does, this is going to cause a problem for anyone with an all-in-one, the OP will be better off looking for a player with optical then.
Old 02-04-2011, 11:17 AM   #103
Paul.B2's Avatar
Yeah it only has coax! Strange decision on Sonys part.
Old 02-04-2011, 11:30 AM   #104
issues with my sony BDP - S380 Blu ray
Could you kindly help inform me on how to resolve the issue list below;
I purchased sony BDP - S380 in Argos yesterday and after setting it up in my house in Dublin, It doesn't show any of the following icons; BBC iplayer, demand 5, qriocity video, love film, sony entertainment tv, but the icons it displays are youtube, eurosport, billabong, bliptv, dailymotion, howcast.com, ustudio, golflink, livestrong.
Thanks in advance for your assistance.
Old 02-04-2011, 11:39 AM   #105
Paul.B2's Avatar
You need to do a firmware update. Connect it to your router with an Ethernet cable, and scroll to the very far left and up to the top. Update firmware from there.
Old 02-04-2011, 12:50 PM   #106
Old 02-04-2011, 12:55 PM   #107
Paul.B2's Avatar
I've already told you how in the post above.....
Old 02-04-2011, 1:11 PM   #108
Thanks but need ur assistance more
Thanks Paul, I did that, when i click update firmware, it says firmware already updated
I tried the video again and still have the same issue
Old 02-04-2011, 4:02 PM   #109
Paul.B2's Avatar
Ok. On the video section if you move up is there an option to refresh video content? I seem to remember there was when I did mine.
Also, what version firmware does it say you're on? Just checking that you are def on the latest one.
I assume the available Internet services are working correctly?
Old 02-04-2011, 4:02 PM   #110
Thanks: Gave 0, Got 5
Is there an option to refresh the video content on the far left menu options, the same way there is on the Sony TVs? If so, try doing that as well.
Old 02-04-2011, 5:13 PM   #111
I check on the video section (althrough) no option for refresh video content. there is a folder there that says erase BD Data, USB device(rear)
I check the version of firmware and it is M06.R.0208
Any further help pls
Old 02-04-2011, 5:44 PM   #112
How about in the network settings. Is there an option to refresh Internet content?
Old 02-04-2011, 5:49 PM   #113
Hi Kenjude,
In the network setting , I have internet setting , network connection diagnostics, media remote device registration, and registaered media remote device
No option for refresh internet content
What does the folder erase BD data do? can it be an issue to the missing icons
Old 02-04-2011, 5:59 PM   #114
Paul.B2's Avatar
Just a thought, you have registered it haven't you? If not go to "network" and activate advanced features and then follow the instructions. Maybe then you'll get the refresh content option.
Your firmware is right up to date so it's not that.
Old 02-04-2011, 6:29 PM   #115
jammyone's Avatar
Thanks: Gave 467, Got 954
Are you sure it's a 380, I didn't think they were available from Argos yet only the 370, 470, 570 & 670 models
Old 02-04-2011, 6:43 PM   #116
Paul.B2's Avatar
Pmsl, I've just checked the argos site and no, it's not available from them. Which model has he got then???
Old 02-04-2011, 6:52 PM   #117
mentm's Avatar
Knowing argos it could be a s360 lol
Old 02-04-2011, 6:53 PM   #118
jammyone's Avatar
Unless they've got stock of the 380 early in NI that don't show up online I assume it's the 370 as the firmware No.s are the same for the two models according to the Sony support site.
Not that it's makes a difference in this case I suppose.
Old 02-04-2011, 7:10 PM   #119
Paul.B2's Avatar
We still havent solved his problem though have we lol. He should still have iplayer etc on a 370 yes?
Come on chuks, put us out of our misery
Old 03-04-2011, 3:30 PM   #120
I've been mooching around on Amazon and came across an HDMI splitter, would this help if I used one of these on the HDMI out at the back of the amp to connect the TV/Blu ray?
