Sony BDP-S370 Owners Thread Part 3
| Post Reply |
| | #511 |
| Member | |
| Quote |
| Advert Log in or sign up to remove |
| Post Reply |
![]() | THE NO.1 HOME ENTERTAINMENT COMMUNITY |
| Post Reply |
| | #511 |
| Member |
I've been using US Netflix on this player over my Xbox purely because it's quieter, but I recently noticed that various items on the Xbox Netflix display 5.1 and have the option to choose between 5.1 and stereo, while the Netflix app on this player doesn't. Is it a limitation of the hardware, or Netflix not keeping older hardware as up to date?
| Quote |
| | #512 |
| Member |
Just in case there is anybody who might be able to help. I bought a 370, just over a year ago, but when I tried to use it for the first time( yesterday) with my amp/ tv etc. but it says no signal from the hdmi output. Anyone encountered this. Afraid Sony told me it was out of warranty and to go and get it mended. Thanks Sony |
| Quote |
| | #513 |
| New Member | question about firmware upgrade improvement
I have a S370 with firmware M03.R.623. Besides BD playing, I use the machine as media player to play downloaded movies (avi, mkv, mp4, etc) via the front USB . On occasions, some video files cannot be played with message "This file is corrupt or unsupported". I read through this thread about what file types & codecs that this player can play already. My question is: if I installed the latest firmware 769, will it expands the codecs to supported from M03.R.623? If I do not want to install 769 as it introduces "copy protection", which firmware level that I should install and where to find it? Thank You. |
| Quote |
| | #514 | |
| New Member | Quote:
| Quote |
| | #515 |
| Senior Member |
no because it will add cinavia copy protection
| Quote |
| Thanks from: | lamcom (06-07-2012) |
| | #516 |
| New Member |
I just signed up to a trial with Netflix UK. If I was to use unblock.us would I still be able to use my existing UK account with the US selection? Is anyone trying this? Thanks |
| Quote |
| | #517 | |
| Senior Member | Quote:
| Quote |
| | #518 | |
| New Member | Sorry for the late answer Quote:
Sony eSupport - BDP-S370 - Support File Description UPDATE Blu-ray Disc™ Player Firmware Upgrade 6/28/2011 Release Date 6/28/2011 M03.R.769 Version M03.R.769 37.65 MB File Size 37.65 MB This utility upgrades the Blu-ray Disc player firmware to version M03.R.769 and provides the following benefits: Improvements over firmware version M03.R.742: Updates BRAVIA® Internet Video to be compatible with YouTube® online service changes. Adds the capability to play 1080/60p/50p video files produced by Sony® cameras. Improves BD-ROM playability. Improves HDMI™ connectivity. Benefits provided by previous updates and included in version M03.R.769: Resolves an issue where an unnecessary warning may be displayed when playing some discs. Adds support for inputting non ASCII characters (Chinese etc) to the player from other devices (iPhone®, iPad®, etc.). Improves compatibility to enhance interactivity with some BD-ROMs. Adds support for DLNA® content Note: The BDP-S270 does not support DLNA functions. Improves router connectivity. Enhanced Gracenote™ Entertainment database browser features: Adds new features such as Related Information Browse and Contents Search to improve your Blu-ray Disc™ movie database. Enhanced photo slideshow: Adds new visual effects and music to add to your photos when they are displayed on a TV. Improved Compatibility: Adds compatibility with DTS® Neo:6® to convert the audio into 5.1 or 6.1 channel format. Resolves an issue where video streamed over the Internet may be displayed at SD (Standard Definition) instead of HD (High Definition) even when using a high speed Internet connection (10 MBps or more) and watching video that is provided in HD. So in sum, you are NOT getting any new codecs, and in my honest opinion they won’t add codecs, conversely, I think they even can remove them (because of patents). A proof of this is the fact that this is the last model with Divx support, newer models play Xvid only. I cannot really tell you what will happen if you upgrade, in fact I want your help to report if any codec is missing after upgrading. In my exceptional case, over 50% of my files are unplayable, but by using tools you can turn them playable (without re-encoding). Did you read a post by me giving links to those tools? By doing so, over 80% of my files are playable. That means 20% is really impossible to turn playable, and they should be re-encoded. But by re-encoding to MKV (AVC/AAC) you will loose almost no quality. If you have more questions reply here or send me an MP, I’ll be glad to answer any question. | |
| Quote |
| Thanks from: | lamcom (11-08-2012) |
| | #519 | ||
| Member | Quote:
| Quote |
| | #520 | |
| New Member | Quote:
I’m waiting for your response. Regards, B-wings | |
| Quote |
| | #521 |
| New Member | About BD playability I have no idea. About wave I think you are referring to *.wav files. I really never played waV files because they are very big, I usually re encode them to AAC to preserve maximum quality so I cannot really tell you. But what I can tell you is that .wav files are in reality containers (as MKV) that means, it is containing encoded audio or lossless (in this case, wav contains PCM or LPCM or even ADPCM most of the time, but in a rare ocassion i saw a wav file containing mp3). Maybe that is the problem, you got an adpcm file contained in a .wav file. To really answer you, I need you to analyse it using mediainfo and then posting the analysis. Thanks.
| Quote |
| | #522 |
| Member |
I don't have any problem, read carefully what I wrote. I read that wav in 44,1 khz couldn't be played anymore with a firmware which was not the last. I don't know if the guy who wrote that tried to play a wav from a cd or a wav "found" on the web. I don't have this problem because my firmware is even older than the "problematic" firmware. So I'd like to know if the last firmware can play wav in 44,1 khz and send it to the receiver in 44,1 khz (without conversion in 48 khz). ![]() I'd also like to know if the last firmware allows to send 50hz videos in 50hz and not converted in 60 hz like with previous firmwares, thanks. I'm not talking about dvd-video but files on USB key, hard drive and dvd-rom. Because with dvd-video, there's no problem, 50 hz stays in 50 hz. |
| Quote |
| | #523 | |
| New Member | Quote:
| Quote |
| | #524 |
| New Member | Streaming files from the computer - how?
Hi, I am another unfortunate BDP-S370 owner suffering from the world turning to x264 and leaving XViD behind (of course, the BDP-S370 has never been able to read even SMALL x264 files from a USB stick, which has made my life hell lately, as more and more people are switching to that format when encoding video). Back when I was using Vuze, the BDP-S370 was at least able to play files that were located in Vuze's download folder. However, since switching to uTorrent, I haven't been able to do that. I'm sure if I were able to stream a x264 file (MKV, MP4) file from my computer instead of a memory stick, the BDP-S370 would be able to play it. But how do I do that? How do I set up a folder on my computer that the BDP-S370 will recognize and play videos from? Thanks! |
| Quote |
| | #525 |
| Member |
It plays x264 videos on USB sticks ! In mp4, mkv and TS containers, you have the choice. |
| Quote |
| | #526 | |
| Member | Quote:
![]() At least for the 44,1 khz problem, because I know that only few people use AVCHD. Thanks | |
| Quote |
| | #527 | |
| New Member | Quote:
Are there types of x264 files I should avoid, then? I thought they were all the same. How do I know when an x264 file won't be readable by the S370? | |
| Quote |
| | #528 |
| Senior Member |
it plays x264 files fine its the mkv container just change the mkvs to mp4s and they will play fine
| Quote |
| | #530 |
| Senior Member |
x264 is the video file in an mkv container you have to unpack the mkv container into it respective audio and video files then remux these into an mp4 container it takes a couple of mins with no loss of quality because your not reconverting
| Quote |
| | #531 |
| New Member |
I've never done this before. Is there a walkthrough for this anywhere? Or is it easy enough that you can just tell me here? What tool do you use for this?
| Quote |
| | #532 |
| Member |
I don't have any problem with MKV, the Sony recognizes this container (and extension). Excepted when its header is compressed, you can verify it with MediaInfo ("header stripping"). If you see that, you can remove this header compression with MKVMerge : file, options, mmg, and tick "disable header ...". There will be no recompression of course, it's very fast. |
| Quote |
| | #533 | |
| New Member | Quote:
Does anyone know how to create a folder on my computer that the S370 can read from a network cable? I believe this would solve all problems. | |
| Quote |
| | #534 | |
| Member | Quote:
The only problem I find is that 1080p stuff suffers; no problem with 720p. Fast forward and rewind can also cause it to throw a wobbly but if you don't need to ff and rw, it works fine. | |
| Quote |
| | #535 | |
| New Member | Reply Quote:
| Quote |
| | #536 | |
| New Member | Answer Quote:
Sony eSupport - BDP-S370 - Support Information My Doc's Got No Nodes: Playing 24-bit wav files from DVD-R on the Sony BDP-S370 Yes, you are right, few people play AVCHD discs, (In fact I never played one) so I am still begging someone to post a reply about a firmware upgrade. If not, I am reluctant to upgrade mine, due to some posts advertising loss of functions. | |
| Quote |
| | #537 | |
| Member | Quote:
I'm talking about wav from cd (LPCM in 44.1/16). Could anyone (who has the latest firmware) make a copy of a track from a cd (with EAC, Nero or any other program), put it on a USB key and play it on the Sony 370 ? You can also convert a 44.1/16 mp3 (or Flac, Ape, MPC ...) to Wav. I also need to know if the receiver gets 44.1 or 48khz , because I wouldn't like to let the Sony convert 44.1 to 48 khz. Thus it's a test to do with Hdmi or Spdif connection, not with analog output that I don't use. My Denon receiver can show the input frequency, I guess most of others can also do that. Thanks a lot ! ![]() edit : If it works with my firmware, you may ask yourself why I'd like to install the last firmware ; it's because it adds compatibility with 1080p videos in 50 and 60 hz (my firmware allows to play 1080p mp4 and mkv in 30 fps maximum), and I'd like to use it (some recent cameras film in 1080p50 or 60 and these mp4 files can be played by the Sony on USB key), unless I lose the 44.1 khz which I often use. Last edited by Music Fan; 28-10-2012 at 11:23 AM. | |
| Quote |
| | #538 |
| Member |
Can I ask what settings are recommended for this player :Output Video Format - Hdmi output - auto or 1080p - fed to LG 50PK590 (full HD plasma) Video Settings • Picture Quality Mode: Selects the picture settings for different lighting environments. • FNR: Reduces the random noise appearing in the picture. • BNR: Reduces the mosaic like block noise in the picture. • MNR: Reduces minor noise around the picture outlines (mosquito noise). I have opted for Theatre Room with non of the these options turned on. Thanks - just not convinced this is upscaling as well as my Sony Ns76 |
| Quote |
| | #539 |
| Prominent Member |
I believe the standard mode is the one to go for as the others colour the output. You don't want any of the other options turned on either.
| Quote |
| Post Reply |
| LinkBack |
LinkBack URL |
About LinkBacks |
| Bookmark & Share |
Digg this Thread! |
Add Thread to del.icio.us |
Bookmark in Technorati |
Tweet this thread |
Share on Facebook |
