I am thinking of getting a blu ray player, possibly a sony bdp s760.
Unfortunately, I am out of touch with technology, and haven't kept up to date with developments since dvd was at it's early stages. However, having recently converted to skyHD, and being impressed by it, I have decided to take the plunge with blu ray.
However, my LCD TV only goes up to 720p/1080i (I should have bought a 1080p set, but it was a bit of an impulse buy at the time). I assume it will be compatible, but is there a big difference in the quality between 1080i and p? I think I saw a thread where some people where arguing that there wasn't a big difference between the two.
I am interested in the Sony as it has wi-fi for convenience. However, I would consider a non wi-fi player as I have a wireless router for my desktop and laptop. At the risk of sounding silly, would I be correct in assuming that I could use my laptop (which has ethernet) to connect to and install firmware for the blu ray player? Or can it not work this way?
Also, I don't have a dedicated AMP/receiver and speaker set. I only have a Yamaha all in one 5.1 sound system (comprising of amp, sub and speakers) which doesn't have any multichannel outputs (last time I checked) nor HDMI output. It is connected to my dvd player via optical.
If I just connect a blu ray player to the yamaha using optical cable, how would this affect playback of blu rays with, for example, 7.1 dolby digital or DTS HD soundtracks and such-like? Basically, will I get sound through my system? I'm not sure on this one, so any help would be much appreciated!
Thanks.
