Hi Jaays,
I do not have the problem you mentioned (Blu-Ray discs do not cause a re-boot when I was at V1.0, although I'm now at V1.1), but I do have other problems!
I wonder if there is a better place to post these issues, possibly where we will get more feedback?
Anyway, I have these:
- When copying from the HDD to a DVD, I am unable to watch anything else on the device. I can not use either of the two Freesat tuners! I have to wait till the copy is complete (which can take ages) and only then can I watch a Freesat channel. This can't be correct can it?
- When playing a DIVX movie from the USB port, it works only at normal speed and the first of the fast forward speeds. At faster fast forward speeds, I see the frames, but when I attempt to play from the new position, it pauses for a while and then very annoyingly goes back to the start of the movie. Can this be correct?
- When watching Freesat, sometimes the picture disappears for a few seconds and then returns. This may be a satellite issue, but signal strength is very good. Not a big issue, just irritating.
- When watching a DVD, occasionally the picture seems to break-up/flicker, but then returns to normal. I thought it was something on the disc, so stepped back and tried again but this time no problems. It does seem to be a random position where this happens. Not a big issue, just irritating.
Hopefully someone can advise on these, thanks.
