Originally Posted by orangefender Sony 32v5500 LCD Tv which I view from approx. 8 feet/2.5 meters
HD Virgin cable
Arcam Alpha 10 amp
Arcam Alpha 9 CD
Monitor Audio GS10 speakers |
One thing to consider is that, if you upgrade to Blu-ray, then you will probably reap quite a benefit in the audio department given your setup. It's kit dependant but I find many people upgrade to HD expecting to be amazed by the picture - and generally they are - but what comes as a real surprise is the leap in audio quality.
As for picture on a 32" screen at 2.5 metres, I have to say I don't think you'll see much benefit. Some scenes will look better - there'll be more detail visible in people's faces - but I doubt you'll be amazed by the quality difference. Of course it all depends where your screens strengths are - I'm afraid I have no idea with your Sony.
If you do decide to adopt Blu-ray, I would urge you to seriously consider the Oppo BDP83
