| no signal problem
I'm not sure in which forum this should go, so apologies if in the wrong one.
My Sky HD box and Sony blu-ray player have worked fine with my LG LCD for months. I feed the Sky and DVD into a switcher and then into the one HDMI input on the TV. Last weekend, after 6 months of no problems, the TV says "no signal" when the switcher is set to feed signal from the blu-ray dvd. No picture, no sound, no menu, no welcome screen, etc.
Changing cables makes no difference.
Removing the switcher from the equation, and connecting the blu-ray direct to the TV hdmi makes no difference.
The order in which the blu-ray or TV is switched on makes no difference.
The TV takes hdmi from the Sky HD box with no problem, so does this rule out a tv problem ?
The blu-ray player went back to the shop, where it worked fine on more than one shop tv. So that rules out the player ?
Changing cables makes no difference, so that rules out the cable ?
My questions are, firstly, if the player, cable, and TV all seem to be fine, what now is the problem, and why has it turned up after 6 months of perfection ?
and secondly, what should I try now ?
Thanking you all in anticipation...
