What connection will give me the best picture?
Old 20-11-2003, 1:28 PM   #1
kenlong69's Avatar
4,009, Level: 14
Points: 4,009, Level: 14 Points: 4,009, Level: 14 Points: 4,009, Level: 14
Thanks: Gave 2, Got 6
Hey all,
I currently have the setup in my sig running along smoothely.
I would however like to be sure I am getting the best picture possible.
I currently have the DVD player connected via an S-Video cable.
Would I get a better picture if I got a decent SCART lead and connected them via RGB composite?
The details of the dvd plater are herE:
http://www.techtronics.com/uk/shop/5...vd-player.html
The details of the tv are here:
http://www.techtronics.com/uk/shop/8...screen-tv.html
Cheers for any help!!!
Ken
Old 20-11-2003, 1:42 PM   #2
8,434, Level: 21
Points: 8,434, Level: 21 Points: 8,434, Level: 21 Points: 8,434, Level: 21
Thanks: Gave 233, Got 115
RGB should be better than S-video, in theory.
Steve
Old 20-11-2003, 1:53 PM   #3
kenlong69's Avatar
4,009, Level: 14
Cheers Steve!
I assume that is only if you have a decent cable?
Is this a good buy?
http://www.audiovisualonline.co.uk/d...5/display.html
Or this?
http://www.play.com/play247.asp?page...G&title=137545
Or would I need a better TV to see a real difference?
Cheers,
Ken
Old 20-11-2003, 2:22 PM   #4
8,434, Level: 21
Hi Ken,
Either of those would be fine. You pays your money... I'm sure your Sony will produce a great RGB picture.
Steve
Old 20-11-2003, 3:13 PM   #5
Illustrious Member
48,568, Level: 53
Points: 48,568, Level: 53 Points: 48,568, Level: 53 Points: 48,568, Level: 53
Thanks: Gave 884, Got 1,285
I would try both RGB and SVHS on the Sony just to make sure!
Old 20-11-2003, 4:24 PM   #6
MartinImber's Avatar
13,078, Level: 27
Points: 13,078, Level: 27 Points: 13,078, Level: 27 Points: 13,078, Level: 27
Thanks: Gave 19, Got 24
RGB is way better than SVideo on Sony TVs
Old 20-11-2003, 4:33 PM   #7
kenlong69's Avatar
4,009, Level: 14
Ok guys...
I just tore evrything apart and compared S-video with an old cheapy SCART... WOW , it's actually heaps better!
Now I have another problem:
I have digital telly and a tivo whick also look HEAPS better in RGB... BUT ... I only have 1 RGB input on the telly!
AAAH!
Is there a way I can get a splitter or something so they can share it?
Or is there a more sophisticated way to do this?
Cheers,
Ken
Old 20-11-2003, 6:49 PM   #8
kelvin's Avatar
8,128, Level: 21
Points: 8,128, Level: 21 Points: 8,128, Level: 21 Points: 8,128, Level: 21
Thanks: Gave 59, Got 39
AAAH!
Does the Tivo not allow you to daisy chain an RGB signal through it? I may be wrong but I seem to recall reading this somewhere... If this is the case, just go:-
Set Top Box ---> Tivo ---> AV1
As a side note, you may find the sticky at the top of this forum interesting reading re. What is the "best" connection
K.
Old 20-11-2003, 6:58 PM   #9
kenlong69's Avatar
4,009, Level: 14
Hey kelvin!
Cheers for that, but that's what I have done. BUT I need to connect my DVD player as well as the Tivo to my TV. The DVD player doesn't suppose Daisy chaining.
I went to js-electronics and they said they are wroking on soemthing that may work.
I'd prefer to get something sooon though!
Cheers,
Ken
Old 20-11-2003, 8:34 PM   #10
mjcairney's Avatar
13,042, Level: 27
Points: 13,042, Level: 27 Points: 13,042, Level: 27 Points: 13,042, Level: 27
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 195, Got 526
If you need to connect more components than you have Scart sockets to accommodate, go here and buy a Scart switching box. I believe they can handle RGB, S-video and composite, so you should be able to do what you want.
Cheers!
Old 21-11-2003, 8:48 AM   #11
kelvin's Avatar
8,128, Level: 21
Apologies, I forgot to factor the DVD into my equation...
I'm sure there definitely is something out there - as mjcairney suggests, take a look at Maplin - I'm certain you'll find some kind of scart switching device there...
Best of luck
K.
Old 21-11-2003, 9:04 AM   #12
kenlong69's Avatar
4,009, Level: 14
No worries Kelvin! I probably didn't explain it very well
mjcairney - It doesn't say on the Maplins site if they support RGB. Bsically I now see the great difference and don't want a cheapish component to degrade it.
In my experience 'splitters' ted to degrade the signal.
Has anyone used one of these Maplin beauties and could confirm whether they will work without degrading performance?
Cheers,
Ken
Old 21-11-2003, 9:22 AM   #13
GrahamC's Avatar
8,737, Level: 22
Points: 8,737, Level: 22 Points: 8,737, Level: 22 Points: 8,737, Level: 22
Thanks: Gave 17, Got 71
Try this...
http://www.lektropacks.co.uk/dept.asp?dept%5Fid=112
Old 21-11-2003, 9:29 AM   #14
kenlong69's Avatar
4,009, Level: 14
GrahamC - AWESOME! That'll do!
Thanks to all for your advice!!! I'll report back once I have recieved this beauty and set it up!
Ken
Old 21-11-2003, 9:36 AM   #15
18,488, Level: 32
Points: 18,488, Level: 32 Points: 18,488, Level: 32 Points: 18,488, Level: 32
Activity: 7.4%
Activity: 7.4% Activity: 7.4% Activity: 7.4%
Thanks: Gave 123, Got 99
Don't know if I'm too late but you can buy the same thing from HERE , considerably cheaper.
That's where I bought mine from.
Old 21-11-2003, 9:40 AM   #16
kenlong69's Avatar
4,009, Level: 14
Cheer Kevo!
Thanks for the heads up but I only need a 2 way connector, I bought the auto-switching one for £34 delivered.
Considering how much I've sunk into this system, £34 is pretty negligable! Hahaha!
Ken
Powered by
 Latest popular product prices
Toshiba SD5010
8 prices from
 £36.54 Click to show/hide the offers
LG BD650
4 prices from
 £69.99 Click to show/hide the offers
LG DRT389H
7 prices from
 £112.99 Click to show/hide the offers
Samsung BD-D5100
8 prices from
 £64.00 Click to show/hide the offers
Sony BDP-S185
10 prices from
 £68.81 Click to show/hide the offers
Sony BDP-S380
6 prices from
 £94.95 Click to show/hide the offers
Sony BDP-S480
10 prices from
 £99.95 Click to show/hide the offers
Panasonic DMP-BDT110
8 prices from
 £99.99 Click to show/hide the offers
 Updated February 13th at 10:30am. Prices include delivery.
