I'm looking at sorting a DVD player and a BD player and seriously thinking that the Oppo might be the way to go but wondering if it's overkill for what I want/need.
I'll be running whatever player/s I get through projector (Pana AE3000 with a 108" (16:9) screen) and initially the sound will be through a basic stereo (no HDMI) setup but when funds allow will go to a decent (I think) amp for 5.1.
I'm not too concerned about whether whatever it is plays CD's brilliantly as and pure music playing is likely to be very very very infrequent. However, ideally I'd like something that is (or can be) both multizone and multiregion.
From all the comments on here it sounds like the Oppo (at approx £600 for multi) sorts out the single player doing both BD and DVD well. The alternative is to look at a two player solution. Looking in that direction it looks like the Pana BD60 (at £200 give or take) would sort the BD side of things. Which leads me to question 1:
- Is there a upscaling DVD player which would be a good option to take care of the DVD side of things at under say £300?
Based on the cost of the Oppo it seems that if there was a stand alone DVD solution at less than £300 then I would save about £100 (but have extra cables and two boxes to deal with). Assuming the answer though is that there is a "recommended" DVD player, I then need to think is the saving worth it. So, questions 2, 3 and 4:
- Are there any views on how the BD capabilities of the Oppo compare to those of (say) the Pana BD60? (And regardless of what people say, I do quite like the ability of the Pana to access you-tube and stills for a bit of a giggle!!)
- How would the stand alone DVD player compare to the Oppo (particularly in the upscaling department)?
- Not having had a setup like this before - how much of a hassle is having two players versus the single player solution the Oppo offers?
Any thoughts/help very much appreciated!
David
