philips dvp5960 hack required ?
Old 16-06-2007, 12:06 PM   #1
3,852, Level: 14
Points: 3,852, Level: 14 Points: 3,852, Level: 14 Points: 3,852, Level: 14
Thanks: Gave 1, Got 0
anyone know if there is a multi-region hack for this player ?
was thinking of buying it from argos, but they dont advertise any of their players as multi-region anymore (although they definately used to at one time , coz friend bought one, and was multi region out of the box)
any help on this would be gratefully recieved.
Old 16-06-2007, 12:34 PM   #2
3,710, Level: 14
Points: 3,710, Level: 14 Points: 3,710, Level: 14 Points: 3,710, Level: 14
Thanks: Gave 53, Got 14
Re: philips dvp5960 hack required ?
If you go to the dvd players forum and type Phillips dvp5960 in the search box there is a massive thread which has loads of info on this dvd player. I bought the phillips a couple of months ago and think it's a great buy!
Old 16-06-2007, 2:27 PM   #3
3,852, Level: 14
thanks a lot
Old 19-06-2007, 7:49 AM   #4
TV MAN's Avatar
1,871, Level: 10
Points: 1,871, Level: 10 Points: 1,871, Level: 10 Points: 1,871, Level: 10
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 2, Got 3
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Apparently this will work on the NEW 5980 as well.
Whitefiver (23-03-2008)
Old 24-06-2007, 2:28 AM   #5
2,473, Level: 11
Points: 2,473, Level: 11 Points: 2,473, Level: 11 Points: 2,473, Level: 11
Thanks: Gave 7, Got 2
just tried this on a budget philips dvp3120 works a treat
D
Old 23-03-2008, 10:18 AM   #6
5,006, Level: 16
Points: 5,006, Level: 16 Points: 5,006, Level: 16 Points: 5,006, Level: 16
Thanks: Gave 8, Got 1
D
Indeed it does. Many thanks for the assistance!
Regards,
White
Old 26-03-2008, 8:37 PM   #7
2,528, Level: 11
Points: 2,528, Level: 11 Points: 2,528, Level: 11 Points: 2,528, Level: 11
D
Yep this worked onb my budget player too thanks
