I’ve just bought the LG DNX190UH made in October 2006 and guess what? None of the handset hacks work! The new Zoran chipset is to blame apparently
Following a brief panic, I found the following procedure and it works!!
So if you are having problems, use the following. The good news is that there is no NTSC judder either so the new chipset must have fixed it.
First you have to download linked file called "LG36868.IMG"
http://rapidshare.com/files/14530611/Zoran.zip.html
1. Then you have to burn this file to a blank CD
2. After burning, insert the CD into the DVD player and press play
3. Then the region management menu will be shown.
4. Input “0” to make it multi-region and then press the “pause” key by Remote Control.
And there you have it, one multi-region LG DNX190UH
Now start enjoying your DVD collection again
