Marantz dv7600 region free hack
Old 29-08-2005, 10:15 PM   #1
4,555, Level: 16
Points: 4,555, Level: 16 Points: 4,555, Level: 16 Points: 4,555, Level: 16
Arrow Marantz dv7600 region free hack
Power on
Open tray
Press buttons on the remote "clear" "2" "5" "8" "0" "clear"
Display shows "TESTMODE"
With the Cursor down until "1215" will be shown in the display
Press buttons on the remote "1" "3" "enter"
Display shows "1213"
With the Cursor up until "1402" will be shown in the display
Press buttons on the remote "0" "0" "enter"
Display shows "1400"
Power On and Off again
Pronto
Old 30-08-2005, 8:31 AM   #2
4,424, Level: 15
Points: 4,424, Level: 15 Points: 4,424, Level: 15 Points: 4,424, Level: 15
Works great! Thanks a lot!!!
Old 25-09-2005, 1:26 PM   #3
jane
Posts: n/a
Marantz dv 7600
Couldn't get this hack to work. After I pressed the first set of buttons, I got a blue screen with some data, but no cursor and nothing saying "test mode." Any ideas?
Old 01-10-2005, 2:12 PM   #4
5,634, Level: 17
Points: 5,634, Level: 17 Points: 5,634, Level: 17 Points: 5,634, Level: 17
Hi!
Well, my dealer entered the code into two players and both players play region 1 and region 2 now. Even region 1 RCE disks.
The dealer entered the code even without a television attached! He just followed these steps exactly :
- Power on
- Open tray
- Press buttons on the remote "clear" "2" "5" "8" "0" "clear"
- Display shows "TESTMODE"
- With the Cursor down until "1215" will be shown in the display
- Press buttons on the remote "1" "3" "enter"
- Display shows "1213"
- With the Cursor up until "1402" will be shown in the display
- Press buttons on the remote "0" "0" "enter"
- Display shows "1400"
- Power On and Off again
I guess that the last part of the number 1402 indicates the region the player is set to (I live in region 2). Changing it to 1400 (2 zeros) makes it a multiregion player :-D
Jeroen
Edit : It's two, not to
Old 20-10-2005, 12:58 AM   #5
Fatoni
Posts: n/a
Cool Marantz dv9500
Does anyone know if the hack procedure for dv7600 also works for dv9500?
Old 20-10-2005, 8:52 AM   #6
8,344, Level: 21
Points: 8,344, Level: 21 Points: 8,344, Level: 21 Points: 8,344, Level: 21
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 8, Got 22
No it doesnt
Old 26-10-2005, 6:32 PM   #7
Fatoni
Posts: n/a
Originally Posted by Geezer
No it doesnt
Does anyone know the hack for dv 9500?
Old 26-10-2005, 7:18 PM   #8
8,344, Level: 21
Activity: 3.0%
It isnt a remote hack, it requires the firmware to be updated by the RS232 port.
Old 30-10-2005, 2:51 PM   #9
13,705, Level: 28
Points: 13,705, Level: 28 Points: 13,705, Level: 28 Points: 13,705, Level: 28
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 315, Got 145
And I don't suppose anyone has this Firmare file?
Old 31-10-2005, 4:23 PM   #10
dj_flower
Posts: n/a
Marantz DV-7400
Can you get this to work on a DV-7400 too
Old 31-10-2005, 7:37 PM   #11
jorgensthlm
Posts: n/a
I did'nt realize that the intended "display" was the display on the dvd-player itself and *not* the display shown on the tv. I'm now afraid I have messed up the settings while fiddling with the remote.
Could someone please tell me the correct settings? (15 two digit numbers, 00xx-14xx)
My numbers are now: 4D 5A 44 37 30 30 38 34 00 00 66 44 13 13 00
Someone, please save me...
Old 01-11-2005, 11:37 AM   #12
8,344, Level: 21
Activity: 3.0%
There is and never was a DV7400????
Old 13-01-2006, 8:10 PM   #13
cR4cKF0x 5TevE's Avatar
4,751, Level: 16
Points: 4,751, Level: 16 Points: 4,751, Level: 16 Points: 4,751, Level: 16
Thanks: Gave 33, Got 78
Dv6600?
Does this work on the DV6600?
Old 13-01-2006, 9:06 PM   #14
6,131, Level: 18
Points: 6,131, Level: 18 Points: 6,131, Level: 18 Points: 6,131, Level: 18
Thanks: Gave 5, Got 102
The file is useless on its own without the pioneer pc interface (as this is based on a pioneer machine!)
Old 13-01-2006, 9:19 PM   #15
13,705, Level: 28
Activity: 1.9%
I'm assuming that's not a) cheap to get b) easy to use ?
Falp (13-12-2007)
Old 05-03-2006, 1:26 PM   #16
Navigatorlat
Posts: n/a
Marantz dv7600
Hey! Thank's for your crack. But really it doesn't work. What do I mean...?.. I had a region 2 player... Some days ago I entered this "codes", after that, I've tried to play disks from region 1,5....Yes, It starts to play, BUT the sounds were cut off.... On region 1 disk I've heard only music, without actor's voice, on region 5 disk I heard as voice, as sounds, BUT the volume of actor's voice was very, very low.....volume of Music was OK. Do anybody have an idea about this bug?
If possible, please mail me to drice@one.lv or Skype to NavigatorLat... Thank's in advance!!!!
Old 02-08-2006, 7:21 PM   #17
Feyst
Posts: n/a
Unhappy
I have the same problem. Please, anybody give the correct code!
Old 02-08-2006, 7:27 PM   #18
6,944, Level: 19
Points: 6,944, Level: 19 Points: 6,944, Level: 19 Points: 6,944, Level: 19
Thanks: Gave 193, Got 132
BINGO!
get the retailer you purchased it from to make it MR for you, if you break it trying to make it MR you wont get it fixed for free
Old 26-03-2007, 11:03 AM   #19
adutra
Posts: n/a
Re: Marantz dv7600 region free hack
Damian
Had you get the firmware? I have the same DV9500 and I'm hardly looking for this firmware.
Thank you
Alexandre
Old 26-03-2007, 11:52 AM   #20
13,705, Level: 28
Activity: 1.9%
Sadly no I haven't got the firmware file. Wouldn't mind just the latest file for the DV9500 nevermind a multiregion one.
Old 26-03-2007, 8:31 PM   #21
adutra
Posts: n/a
Damian
If you live in USA try this:
http://www.jvb.nl/jvb.asp?level=modi...itle=846&cur=2
Unfortunately I live out of USA.
Alexandre
Old 26-03-2007, 8:51 PM   #22
13,705, Level: 28
Activity: 1.9%
Nah....I'm in the UK. Looks like you ship the player to them to get it modded anyway. As far as I know Marantz will make it multiregion themselves. I just don't fancy sending my beloved player anywhere.
I have a Samsung BD-P1000 for any multiregion DVD's now and keep the Marantz for Region 2 material and CD's as it's a better player in both departments.
Roll on a multiformat Blu-ray, HD DVD, SACD, DVD Audio and bloody good CD player from Marantz/Denon/Pioneer!!
Old 26-03-2007, 9:31 PM   #23
adutra
Posts: n/a
The same for me. I have another DVD Player a Toshiba SD, region free, not so good but enough to enjoy movies.
My thecnic call the guys of Marantz and they said that don't send the firmware.
Another possibility is change the chip for another with region free.
If you have any notice about how to get this firmware, please post here.
If I know something about this I'll do the same.
Thank you.
Alexandre
